trunk and door lock set replacement!!! HELP
Old Dec 21, 2008 | 04:25 AM
vargasjc's Avatar
I lost my key to the door and trunk of my firebird...i have the key to the cylinder and i can start the car because luckily i left the door unlocked...
I want to change the lock set for the trunk/doors because i am its an open invitation for an esay break in...
I was wondering...has anyone ever changer the whole set and explain to me the easiest way?
I cant even open the trunk from inside the car...(there is no trunk hatch) evenm from inside the car...only way to open it is from outside with the missing key...
Its a 89 firebird...PLEASE HELP!!!
Old Dec 21, 2008 | 06:20 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: trunk and door lock set replacement!!! HELP
more than once. i carry just a door key in my wallet.
go to any locksmith and they can give you a key to match right there, or they can change the keys there too. i said lock smith, not one of those places where some clerk copies a key, but a real lock smith. every neighborhood has at least one. but there may be a lot of labor charges involved.
you pull the cylinders yourself and have them make one key to fit each of them. but its a bit of a pain to do that.
chances are the person who found you key has no idea what car it fits. or you can pull all the key cylinders and take them in and it will be cheaper to do them out of the car.
good luck
Old Dec 21, 2008 | 07:20 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Go to Dealer with your Vin & proof of ownership and get new keys made. Could be cheaper then replacing the lock cylinders. Or call a locksmith and see what he can do for you. More options then you thought you had.
Old Dec 21, 2008 | 07:34 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
A single post about a problem is usually sufficient.
JamesC
Old Dec 21, 2008 | 09:43 AM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Answer to your questions: Yes, Ive changed the whole lock set. Cost was $85 from Classic Industries for lock set without ignition. Best estimate I got from a local locksmith was $45 labor to re-code a cylinder. Don't know about getting a key made, but $45-75 seemed to be the walking in the door price.
I don't know any easiest way. The door trim panels have to come off to get to the cylinder retainers. The hatch you can either break the center tail light/cylinder bezel to drill out 2 rivets holding it in or try prying out passenger side of inner trim panel to get you arm behind it. Or break it where your striker pokes up through. Easiest to repair/hide in my opinion. You will be trying to pull the cable going in to latch loose to pop it.
Old Dec 22, 2008 | 08:31 AM
ACCLR8N's Avatar
PM replied to.
Here are pictures of the rod clip I tried to describe. In the pictures the locking tail has been pried up and the clip slid out enough to let go of the notch in the rod.
Attached Thumbnails trunk and door lock set replacement!!! HELP-rod-clip1.jpg   trunk and door lock set replacement!!! HELP-rod-clip2.jpg   trunk and door lock set replacement!!! HELP-hatch-cylinder.jpg
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
