Okay, Trans Am gurus
Old Dec 27, 2008 | 08:53 AM
blg0720's Avatar
Car: 88 GTA
Engine: 305 V8 LB9
Transmission: 4 sp. Auto-4L60
I have NEVER seen a Trans Am without body side molding. EVER. But I've had two or three different body shops(including one restoration place) tell me TAs did not come out of the factory with body side moldings.
Fact or Fiction? I want to do it right when I repaint it.
Old Dec 27, 2008 | 09:23 AM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: Okay, Trans Am gurus
Your 83 didn't have them but from 85 and up all t/a's had them
Old Dec 27, 2008 | 10:15 AM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
You mean GFX, right?
My 84 just has little things in fron of the wheels, almost like spats, but way small, I consider it non-GFX
Old Dec 27, 2008 | 11:11 AM
89junkyardgta's Avatar
Car: 1989 GTA, 1985 T/A
Engine: L98, LG4
Transmission: Slush-o-matic 700R
Axle/Gears: stock and stock
Ok, here is the deal. 1982-1984 Trans Am did have GFX, but they are the small 'spat' types that bradley is talking about. Yours is an 83, and I by what I can see your car is correct for 1983. Post some better pics to help us verify. You car from the factory had a small ground effect at the front of the front wheels and at the front of the rear wheels. That's it, and it is correct. If you wanted to run GFX that would be correct looking, you could look for the Aero ground effects kit, which was factory on 1983 Daytona pace cars, or an option on the 1984 Trans Am. They are similar but different to the 85-90 GFX. But in short, your car is correct without the ground effects.
Old Dec 27, 2008 | 11:24 AM
Stephen's Avatar
Car: 87 GTA
FX or those door ding prevention strips?
I have both...
Old Dec 27, 2008 | 11:34 AM
blg0720's Avatar
Car: 88 GTA
Engine: 305 V8 LB9
I'm not referring to GFX. I was pretty sure those were right (but thanks for the confirmation! ) I'm talking about the "ding strips" on the doors...between the wheels along the side. (Forgive the previous owner...for he knew not what he had!)
Side note: How could ANYONE let these get in this shape?! This is what it looked like when I picked it up!
Old Dec 27, 2008 | 12:05 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
the door ding strips did come from the factory. and good job saving her, I hope you slapped the previous owner! lol
Old Dec 27, 2008 | 01:07 PM
blg0720's Avatar
Car: 88 GTA
Engine: 305 V8 LB9
Well, in his defense, it wasn't completely his fault. Although, he WAS going to make her into a KITT. BUT, he had three turbo casts, sent them off to get cleaned and never saw them again. He bought the poor thing from a salvage yard for $600, where someone had been trying to sell it for a few years.
He DID put on a new radiator, heater core and hoses, fuel pump, took the computer out, put in the carb, and did some MAJOR work on it before I bought it off him for $750...pre-KITT conversion. I drove it all the way home (three hours) and the only reason I had to call a tow is because I got a flat tire!!
Caveat: I DO know how to change a tire...the trunk had no lock cylinder and couldn't be opened!
Old Dec 27, 2008 | 04:38 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
My 86 T/A didn't have any.
Old Dec 27, 2008 | 04:49 PM
guess someone removed them then?
sorry,I thought you were orig. talking about the gfx.
Yes those ding strips do appear to be orig.
Last edited by TIMMYS89GTA; Dec 27, 2008 at 04:50 PM. Reason: Automerged Doublepost
Old Dec 27, 2008 | 04:56 PM
Stephen's Avatar
Car: 87 GTA
A previous owner could have removed them, or the original buyer could have had the stealership take them off.
When I bought my 97 Tahoe, the 4 factory chrome wheel well lips came off on day 2. And the door ding strings came off the first weekend I had it. Black Tahoe & the strips came off with zero pant damage. Not hard to do with the right stuff.
Old Dec 27, 2008 | 05:09 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
The parts catalog lists them for all birds. I don't see why they would've gone with anything else. Although, I would go with the later style. My '87 and '91 have smoother looking ding strips than my friends '85. The '85s look like they were added from a JCWhitney Catalog.
Old Dec 27, 2008 | 05:25 PM
Car: 86 T/A
Engine: 5.0 TPI
guess someone removed them then?-----------
I guess I should have been more specific. My RPO sticker doesn't show a B9K option as having been installed on my car. And it came new without bodyside mouldings. Although if it did show the option, I guess the dealer could have removed them.
Old Dec 27, 2008 | 05:28 PM
blg0720's Avatar
Car: 88 GTA
Engine: 305 V8 LB9
I DO know that my mechanic said they were riveted to the door. Does that help any indication? Geesh, this is frustrating... Maybe we'll never know?
Old Dec 27, 2008 | 05:31 PM
Car: 86 T/A
Engine: 5.0 TPI
If the mouldings on the car in this pic are aluminum rails with seperate end pieces and a colored plastic insert, they were aftermarket and probably applied at the dealer. Pretty common back in the day. Any factory bodyside moulding would have been stick-on.
Old Dec 27, 2008 | 05:34 PM
blg0720's Avatar
Car: 88 GTA
Engine: 305 V8 LB9
That answers that, then! You are absolutely right! The inserts are all drawn up, too, and they look HORRIBLE. I'll be happy to get them off!
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
