locks
locks
i locked my keys in my camaro the other day and someone told me that if i stick something thin down in the window i could push the locking rod down and un lock the door so i tired it and it wouldn't work so i tired something else and i was able to unlock the door and get my keys but now my door lock wont lock or unlock from the out side the key just turns in the lock and feels like theres nothing there cause it used to be harder to turn the key now its just nothing what do u alll think the problem is and how can i fix it
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
Re: locks
you will have to take the door panel off to be sure, but you probably just disconnected the bar that runs from the lock to the handle
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: locks
Check the following diagram (the rod is held in place by a plastic piece, IIRC, and becomes brittle after years of heat/cold):https://www.thirdgen.org/forums/atta...on-manual1.jpg
JamesC
Car: 85 Camaro IROC
Engine: 5.7 TPI
Re: locks
i have an 84 caprice classic that i have replaced all four plastic thingies in.
each one went bad randomly.
it sucks too because its a little piece that costs less than a dollar, but you have to completely take apart the door to get to it and replace it.
have fun...
have fun...
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Re: locks
i was able to get in my trans am with a flat head screw driver into the key hole for the door.
amazing how easy it was to break in but next time try that took literally 2seconds and i was in
and didnt ruin anything inside teh lock for the key
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: locks
pay for the lesson so you dont do it again and if you do you know what to do
call a tow truck driver
he will probably use a jimmy and will not want you to watch while he does it but oh well you have the money
buy a jimmy and practice makes whatever perfect might be
Car: 86 T/A
Engine: 5.0 TPI
Re: locks
Sounds to me like your lock was already broken. You shouldn't be able to turn it with a screwdriver.
Axle/Gears: no idea
Re: locks
well i dont want this post to be a huge thing over its supposed to or not
just saying my cars door locks work fine with my key
and on ocassion when i couldnt get in the car i was able to use a smaller flat head screw driver and get in my car very easily
im not sure how or what could be broken for me to still be able to use the key in my locks effectively
im sure people would want locks on their cars taht a simple screw driver cant penetrate but i have no answers
just sayin my car can be broken into with a screwdriver and has not affected how my locks work with my key since
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
