body
Old Feb 8, 2009 | 09:02 AM
bruce lamoureux's Avatar
Car: 1991 firebird formula
Transmission: auto.
Axle/Gears: ?
body
just painted my car this winter with a acrlic enamel ,and am getting ready to shoot the nose and rear plastic parts again ,(the first time they cracked)then i heard of some kind of clear that you put on before you aply paint .the qustion is can i shoot clear over the top or do i need to skuff before apling clear ? was planing to all the parts back on the car then shooting the car all at once.
Old Feb 8, 2009 | 09:14 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Re: body
I'm going to say your probably going to want to scuff before you clear.
The clear needs something to "bite" onto.
Old Feb 9, 2009 | 04:33 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Re: body
why are you putting clear over enamel?
Old Feb 9, 2009 | 04:38 PM
Transmission: auto.
Axle/Gears: ?
Re: body
i heard that it gives you a better shine !
Old Feb 10, 2009 | 06:54 PM
Engine: 5.7
Re: body
If it's done right....you can make enamel shine just as good as clear. I painted my car with enamel...and it outshines alot of clear jobs I've seen. If I had to go back.....I would use 2 stage...but I was only 19 when I painted my car and didn't know much. Plus..it was pretty cheap.
I'm not saying my car has the best enamel paint job....but alot of guys find it hard to believe it's a single stage paint...
Old Feb 10, 2009 | 08:55 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: body
Did you paint that yourself ?
Old Feb 20, 2009 | 05:40 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
Re: body
if you have crack in the paint you have to take it all back off or the cracks will just come right back, proper application and buffing will make it shine.
in 2k paint we add flex aditive sometimes, the newer best paint dont need it so maybe yours does ask at your supplier if they have a flex additive for the plastic parts.
Old Feb 23, 2009 | 08:39 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: body
you can clear over enamel
I just had my hood peel up like a banana
I got mad at it and took a 10lb slege to it
none of the paint popped off
what to know why
enamel sticks to stuff better than base
if you painted your bumpers with base and no flex agent your paint would pop off
sand the cracks out in the bumper and most of the enamel
then recoat with enamel and flex agent
the only way I would know is I have to do the same thing
Hotrodboba400
Dec 10, 2019 07:07 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Silver Spear
South East Region
18
Dec 4, 2015 09:59 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
Kenwood
Sep 4, 2015 05:50 PM
