Here Is my Project Finally back on the ground 1986 Iroc with 468 BBC
Old Mar 8, 2009 | 12:36 AM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
Finally got it mostly back together. I have radiator hose, Both Dipsticks, Altimator Belt, Wire up fuel pump and electric fan, and hook up the shifter cable add trans fluid. I also need to get a cowl scoop. looking for either a 3 or 4 inch. Once that is on I will reshoot the hood Front bumper, drivers fender and then finish the strips on the front. alittle about the car. right now it has a 486 that is right around 600 hp. behind that it has a stock 700r4 I know won't last long. and the rear is a stock rear with 3.42 gears. but today was a mile stone the car is almost complete Minus the few parts i mentioned.
Old Mar 8, 2009 | 09:43 AM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
Re: Here Is my Project Finally back on the ground 1986 Iroc with 468 BBC
looks pretty good!!! I kinda like the look of the black hood, lower lip and head light area...lol. Should look pretty sharp once you have the cowl scoop on and everything painted. now with a 486 under the hood does the front end sit any lower? with a 600hp big block on a t-top car do you have sfc yet? again look real good so far!!
Old Mar 8, 2009 | 10:39 AM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
car sits the same height as with the 305 tpi that was in it sfc not yet but it does have a 6 point roll bar which stiffened it alittle. I forgot about the sfc i had planned on that.
Old Mar 8, 2009 | 04:10 PM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
today I gave the mechanicals a rest and worked on dressing the car up alittle tell me what you think I cut the vinyl myself and made the badges myself. here's the Pics
Old Mar 8, 2009 | 04:15 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Didn't you say 486, not 454?
Old Mar 8, 2009 | 04:23 PM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
Yea but it started life as a 454 LOL I didn't have graphics for 468 the 454 graphics came from the vector i have for the 454 ss truck
Old Mar 8, 2009 | 04:25 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Makes sense!
Old Mar 10, 2009 | 02:03 PM
87IROC NO TTOP's Avatar
that white with the red looks awesome. one of my favorite color combos for sure.. i also like the big block power plant. your car looks great and i bet it'll scream to
Old Mar 10, 2009 | 02:09 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Looks good... How many MPG are we looking at?
Old Mar 10, 2009 | 04:06 PM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
Thank you I have put alot into this car. time wise not Money but time. well more cash than I want to admit. I just figured it out with the motor and the car and fixing alot of the car. here is the spreadsheet i have been working off of. as you see i still have a few things to buy.
1986 Camaro Iroc $1,100.00
Paint $200.00
Speakers $30.00
BBC 468 $2,500.00
Floor Mates/Seat Covers $78.00
Seats $100.00
Coloum $75.00
Roll cage $0.00 Done
Carpet $0.00 Not Doing
Interior Paint $0.00 Not Doing
Trans $0.00 Done
Headliner $20.00
Sub Frame Connectors $0.00
Brakes $80.00
Shifter $0.00 Done
Chin Spoiler $125.00
Headers $187.00
Exhaust $0.00
Door Panels $0.00 Not Doing
Back Half $0.00 Way Later
Axel Housing $0.00 way later
Gears and Axel $0.00 Way Later
Fuel Pump $60.00
Flex Plate $50.00
Tach $89.00
4 inch cowl scoop ( I need this Bad anyone have one laying around)
total of about $4595.00 Shhh don't tell the wife
Old Mar 10, 2009 | 04:07 PM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
also when you go Big Block MPG isn't MPG It's GPM (Gallons per Mile) LOL
Old Mar 10, 2009 | 04:25 PM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
here's the rpo list on the car
Thirdgen.org -- RPO Decoder
9NM: SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
86P: WHEEL COLOR, GRAY METALLIC
86A: STRIPE COLOR, ACCENT, TWO TONE RED/GUNMETAL (91)
8NM: SPRING, COMPUTER SELECTED, REAR, LEFT HAND
729: SEAT BELT COLOR, DK CARMINE (9) (91)
72C: TRIM COMBINATION, CLOTH, DK CARMINE (C)
7ZX: SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
6ZX: SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
40U: PRIMARY COLOR, EXTERIOR, WHITE (91)
11Q: MOULDING COLOR, WHITE
1AY: ???
Z28: MERCHANDISED PKG, SPECIAL PERFORMANCE
YT9: ???
YT1: BUILD UP DR & QTR
YS1: SEAT,RR CUST
YR1: SEAT,FRT CUSTOM
YE2: CONVENIENCE PKG, DECOR LEVEL #2, LOW TRIM
V73: ANTENNA, FIXED
U79: SPEAKER SYSTEM, 4, DUAL FRT COAX, DUAL EXT RGE PKG
U29: LAMP, INTR I/P, COURTESY
U26: LAMP, INTR, ENG COMPT, COURTESY
U25: LAMP, INTR, RR COMPT, COURTESY
U21: CLUSTER, INST, OIL, COOL TEMP, VOLTS, TACH
UX1: RADIO, AM/FM STEREO CASSETTE EQUALIZER
UP8: STEREO RADIO INSTALLMENT PROVISIONS
UA1: BATTERY, HEAVY DUTY
T96: LAMP, FOG
T93: TAIL & STOP LAMP, SMOKED
T63: ALARM, HEADLAMPS ON WARNING SYSTEM
TR9: LAMP, GROUP
QDZ: TIRE ALL, P245/50VR16/N BL R/PE ST TL HW4
P20: HUBCAPS, WHEEL, STYLED
N96: WHEEL, 16 X 8, CAST ALUMINUM
N65: WHEEL & TIRE,SPARE, SPACE SAVER, STEEL
N33: STEERING COLUMN, TILT TYPE
NK3: STEERING WHEEL, SPORT, SOFT RIM, SIMULATED LEATHER
NA5: EMISSION SYSTEM, FEDERAL, TIER O
MXO: MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
MD8: TRANSMISSION, AUTO 4 SPD, THM 700 R4
LB9: ENGINE, GAS, 8 CYL, 5.0L, TPI, HO
K90: GENERATOR,108 AMP
K34: CRUISE CONTROL, AUT0MATIC, ELECTRONIC
J65: BRAKE SYSTEM, PWR, FRT & RR DISC
G92: AXLE REAR RATIO, PERFORMANCE
G80: AXLE POSITRACTION, LIMITED SLIP
GU5: AXLE REAR, 3.23 RATIO
FE2: SUSPENSION SYSTEM, RIDE HANDLING
E9Z: SPEEDOMETER KEY (DELETE)
E5Z: SPEEDOMETER ADAPTER (DELETE)
D88: DECAL, STRIPE, SPORT
B91: ORNAMENTATION, EXTR MLDG DR EDGE GUARD, COLORED
B9K: ???
B84: ORNAMENTATION, EXTR MLDG, B0DY SIDE
B4Z: IROC PACKAGE
B35: COVERING, REAR, FLOOR MATS CARPETED INSERT
B34: COVERING, FRT FLOOR MATS CARPETED INSERT
B18: ORNAMENTATION, INTR, DELUX
BS1: INSULATION, ACOUSTICAL PKG
A90: LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
A31: WINDOW, POWER OPERATED, SIDE
A01: WINDOW, TINTED, ALL SHADED, W/S
AU3: LOCK CONTROL, SIDE DR, ELEC
AR9: SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AM9: SEAT, RR, SPLIT, BACK, FLDG
Steven 86IROC-Z
Mar 28, 2026 06:42 PM
Frozer!!!
Jan 19, 2024 04:55 PM
backtothe80s
Sep 5, 2015 12:39 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
mustangman65_79
Aug 11, 2015 03:17 PM
