Front license plate holder - 89 Firebird
Old Mar 9, 2009 | 07:26 AM
slym_dee's Avatar
Car: 89 Formula 350
I've been using the "what are the odds they'd pull me over for this" strategy with my 89 Formula for awhile now and i decided that before my luck runs out i'd conform to the rules. So i'm looking for advice for the best bracket for the triangular nose of the 3rd gen Firebird. Thanks for any advice you may be able to offer.
Old Mar 9, 2009 | 08:07 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: Front license plate holder - 89 Firebird
Check out the APR-400U....Foldaway license plate holder. Also comes with motor and remote
http://store.summitracing.com/egnsea...=KeywordSearch
Old Mar 9, 2009 | 09:00 AM
Firebat's Avatar
No bracket. Screw it directly to the nose and bend the plate slightly in the center. This works best if you have license plate numbers that are printed on and not embossed/pressed out. Or do what was mentioned above.
Old Mar 9, 2009 | 11:17 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
I'm going to keep an eye out for a newer style car with a plastic holder that might fit or be easy to modify. A nice black plastic molded holder would look a lot better than the brackets and plate that are supplied from the factory.
Old Mar 9, 2009 | 11:27 PM
Stephen's Avatar
Car: 87 GTA
Use the feature, here on TGO. It'll give you threads like..... Hidden Front License Plate Holder
Old Mar 9, 2009 | 11:52 PM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
i put mine in the windshield but im sure m luck will run out.
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
mustangman65_79
Aug 13, 2015 07:36 AM
