Anyone ever had the tumblers replaced in door lock cylinders?
Old Mar 13, 2009 | 07:31 AM
88TransAmFreak's Avatar
Car: 1971 Camaro
The reason why I ask is because my door handles and locks have been painted over when the car was painted.
I'm swapping the handles to brand new black ones and need to replace the painted lock cylinders with new ones as well.
I can go to the auto parts store and pick up the cylinders, but they will obviously come with new keys. The key that opens the door on my TA also unlocks the tops and the rear cargo glovebox.
So my question is, have you ever replaced the tumblers in the door locks? I'm thinking about taking my key and new locks to a locksmith and let him re-key it, I'm sure that can be done correct?
A cheaper solution would be for me to try and swap the tumblers out, I just don't want to get myself into a mess....any ideas on that?
Old Mar 13, 2009 | 07:52 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Anyone ever had the tumblers replaced in door lock cylinders?
Post #10 in the following link will show you an expanded view of the area in questions:
https://www.thirdgen.org/forums/body...servation.html
BTW, removing part #5 for me personally was one son of a gun.
JamesC
Old Mar 13, 2009 | 07:57 AM
Car: 1971 Camaro
Thanks James, I was mostly meaning the tumblers inside the lock cylinder...the part inside the cylinder that is unique to whatever key you used to open the door.
I appricate the help
Old Mar 13, 2009 | 08:07 AM
JamesC's Avatar
It's been a while since I messed with those, so I don't recall if the cylnder/tumbler was a unit or not. In my case, the tumblers were frozen. I simply replaced the cylinder and, IIRC, had it keyed correctly.
JamesC
Old Mar 13, 2009 | 03:47 PM
steve87ta's Avatar
Car: 1969 firebird, 1986 Trans Am,
Engine: 461,305TB
Transmission: T-10,700r4
Axle/Gears: 3.55,2.73
Yes a good locksmith can set one up to work on the same key. My father is and my grandfather, was a locksmith. They are whats called a side bar cylinder. Come to think it is nice he sets up all my cars for free!
Old Mar 14, 2009 | 12:18 AM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
The black cover and spring loaded doors on the cylinders can be replaced seperately without messing with the rest of it. Most of the time when you purchased a new GM lock cylinder it came disassembled and without keys and needed to be coded to your existing key. It was actually pretty simple to put one together if you had the parts.
Old Mar 14, 2009 | 07:12 AM
Car: 1971 Camaro
Thanks! I'm going to pick up a set of cylinders and see if I can swap the tumblers out myself, unless I can find a new set of black covers first.
Old Mar 14, 2009 | 10:21 AM
Car: 86 T/A
Engine: 5.0 TPI
Check with a local locksmith to see if they have the covers. The OEM cylinders have the cover crimped over on the back and it can be hard to get them apart without damaging them. The replacement covers have tabs you bend over to hold it on.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Zachattack0925
Aug 12, 2015 09:52 PM
