UPDATE: Door Sag Eliminated
Old Mar 24, 2009 | 10:40 PM
KDXmike's Avatar
Hey guys
Just wanted to give you an update on the door sag problem. I ordered a hinge kit from Top Down Solutions and it worked great. I also went ahead and ordered a striker bolt and detent spring from TDS as well. Luckily my brother in law owns a shop and did the work for me. The door closes perfectly and I'm thrilled to say the least.
My door hinges were in very bad shape. The lower bushing was missing for so long that the pin was wearing on the joint which made the hole bigger. My brother in law used an oversized bushing to correct this and it worked out beautifully.
Now instead of lifting the door to close it I can just swing it shut with two fingers and 'bamo'. Perfect!
So, after one month of work I have the following done on my '88 IROC 350.
New:
Emergency brake cables
Rear brake bads, calipers and rotors
Front struts
Rear shocks and swaybar
Fixed door
4 new tires
Front end alignment
GT Grant steering wheel
Now on to phase II... Cheers to TDS, I love the door now! Before and after pics to be posted soon.
Mike
Old Mar 25, 2009 | 06:53 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: UPDATE: Door Sag Eliminated
yeah man,I remember your little video from the original thread.
Glad to hear you got it all fixed up.
Now, what exactly was phaseII again?
Old Mar 25, 2009 | 10:37 PM
KDXmike's Avatar
Phase II is where the rust spots underneath get cleaned up before painting. I had to spend some cash to get the emergency brake fixed before I venture underneath. I've owned the car for over 15 years now any luckily it has been safe from rain during much of that time.
On a side note. The stock upper door hinge pins have to be cut off to be removed as most here are already aware. The Top Down Solutions upper pins are bolt in. So removal of the old pins are tougher than the installation of the TDS pins.
Mike
Veaceonee
Sep 29, 2016 08:15 PM
LC2 TECH
Interior Parts Wanted
Jan 27, 2016 08:38 PM
InfinityShade
Sep 18, 2015 08:32 PM
Buggy Disaster
Sep 17, 2015 05:12 PM
IROCZDAVE (88-L98)
Sep 17, 2015 07:43 AM
