painted wheels
Old Mar 27, 2009 | 09:22 PM
bph270's Avatar
Car: 1984 camaro
Engine: 355 sbc mildly built
Transmission: th350 w/shift kit and megashifter
Axle/Gears: 272 posi borg warner
painted wheels
hey guys i got some stock z28 wheels that have been completly painted grey. i would like to get the paint off the outter lip and inside lips. how can i do this with out messing up the aluminum face? any ideas would be great. thanks
Old Mar 30, 2009 | 11:54 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Re: painted wheels
Aircraft alumnimum stripper works good on the wheels and will not hurt the base metal. The problem is it will strip the clear coat off the lips. But I would suggest sanding and polishing the parts you want to remain unpainted. You can also re-clearcoat it but make sure you have all the dust/dirt/grease and brake dust off the wheels or it will yellow the clear coat when you spray it. The wheel refinishing kit from east wood works great. Just make sure you have either a good drill or a grinder motor with a extension because it will burn out cheap drills.
There are a few threads about this process search for polishing wheels.
btw the wheels on my car were painted white when I bought them for 100 bucks, no curb rash perfically straight wheels.
Old Mar 30, 2009 | 02:55 PM
Mathius's Avatar
Re: painted wheels
Mask the areas you don't want the paint removed from and then use some lacquer thinner.
Mathius
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
kah992
Aug 19, 2015 02:55 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
