Where to buy this bracket for T/A GFX????
Old Apr 4, 2009 | 05:16 PM
KJZ28/TA's Avatar
Car: 2002 Camaro
Engine: :(
I have a 1986 Trans Am.
Ok Where can I get the bracket for the SIDE ground effects that goes on the front fender. I had a thread like this and ended up buying the wrong brackets from Hawks, so I don't mean the brackets on the front of the fender, I mean the ones on towards the rear for teh GFX skirts.
Thanks in advance!!!
Kevin j.
Old Apr 5, 2009 | 09:57 PM
KJZ28/TA's Avatar
Car: 2002 Camaro
Engine: :(
Re: Where to buy this bracket for T/A GFX????
Does no one know where to get this? I tried a search already, and I would think this would be a mass produced part because I see people with the same problem, this bracket rusts and crumbles, leaving the front of the GFX popped off.
Old Apr 6, 2009 | 10:01 AM
steve87ta's Avatar
Car: 1969 firebird, 1986 Trans Am,
Engine: 461,305TB
Transmission: T-10,700r4
Axle/Gears: 3.55,2.73
Not sure exactly what you mean. The ones on my wife's 87, on the rear of the front fender is just a strip of metal that some studs attach to and go through the holes in the fender. I made some with some metal and a welder. The original ones have a square holes and a curl at the top and bottom. (prob to help with them smoothly slide in the GFX and not pull in the edges.)
Old Apr 6, 2009 | 12:56 PM
KJZ28/TA's Avatar
Car: 2002 Camaro
Engine: :(
That sounds like the spot I am talking about. So I guess no one makes it. Was it easy to make yours?
Old Apr 6, 2009 | 03:14 PM
steve87ta's Avatar
Engine: 461,305TB
Yes it was easy, just get some flat sock(11/2 or 11/4 can not remember) and mark the holes and weld some studs or bolts with the heads cut off in those spots. Tighten with nuts/washers on the inside of the fender. They (the newly made bracket) pop in a hem seam in the urethane GRFX part. HTH
Old Apr 11, 2009 | 09:55 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Kevin j.
I was looking for another item out in the garage and found the bracket you're talking about. Do you still need one?
Old Apr 12, 2009 | 09:13 PM
KJZ28/TA's Avatar
Car: 2002 Camaro
Engine: :(
Really? You have a picture? PM me.
Old Apr 12, 2009 | 09:21 PM
Car: 86 T/A
Engine: 5.0 TPI
here's a pic
Old Apr 12, 2009 | 09:30 PM
KJZ28/TA's Avatar
Car: 2002 Camaro
Engine: :(
Dang that looks like it!! How much you want for it?
Old Apr 12, 2009 | 09:38 PM
Car: 86 T/A
Engine: 5.0 TPI
I knew you were going to ask that! ... I never know what price to charge for my junk! Is it worth 5 bucks?
Old Apr 12, 2009 | 09:55 PM
KJZ28/TA's Avatar
Car: 2002 Camaro
Engine: :(
I am the same way. But that is about right for that piece becasue I bought the wrong ones that are bigger then that for $10. So half the size, half the price. What would shipping be to 10509? You have another? or is that it?
Old Apr 12, 2009 | 10:01 PM
Car: 86 T/A
Engine: 5.0 TPI
I was going to ship it for that price. I could look around and see if I have another. You never know what you might find out in the garage.
Old Apr 12, 2009 | 10:09 PM
KJZ28/TA's Avatar
Car: 2002 Camaro
Engine: :(
Sweet. Ill pay that shipped $5. How do you take payment?
If you could find the other bracket that would be great!!!!!! Both sides of mine are rusted to bits.
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 11, 2015 05:16 AM
snakeshooter
Sep 7, 2015 11:15 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
