So I am going to do a rotisserie
Old Apr 13, 2009 | 04:04 PM
Sovuf's Avatar
Car: 86 IROC
Engine: Soon 355
I plan on doing a rotisserie on one of my third-gens very soon. Could anyone give me any tips on things I should watch for? Any information would be really appreciated.
Thanks!
Old Apr 13, 2009 | 07:02 PM
Ricco's Avatar
Car: 2011 Cummins HO
Engine: 350 HSR
Axle/Gears: 3.43
Re: So I am going to do a rotisserie
Dont drop it...
Old Apr 13, 2009 | 08:58 PM
Sovuf's Avatar
Car: 86 IROC
Engine: Soon 355
I will be aware of that
But i did mean things like bolts that will break easy, things that may break and etc.
Old Apr 14, 2009 | 08:19 AM
Ricco's Avatar
Engine: 350 HSR
Axle/Gears: 3.43
Sorry, couldnt resist
There was a guy on here who had built one out of wood, looked to be pretty good - a lot of people were asking for his plans.. Maybe doing a search will bring up that link for ya!
Old Apr 16, 2009 | 12:10 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
is it a t-top? I assum the car will be fully striped with now doors etc. Are you wanting to know the best mounting points etc.
If its a t-top I would probably weld in a temp brace to keep the body from flexing as you roll it over. I've never done it before but from a pure structual point of view I think it would be needed.
Old Apr 16, 2009 | 01:00 PM
Camaro0605's Avatar
Car: 1991 RS
I think you are referencing me...
I don't have any plans for it as it is at my dads and he lives about 2 hours away. I usually go up there to work on my car about 2-3 days a month at most and try to get as much done on the car when i'm there, which doesn't leave much time for anything else.
We still have the frame of the rotisserie in tact in his garage and i'd still like to eventually write up how he did it. As much as i have learned from this site it would be the least i could do.
I did not brace the body at all and looking back i wish i did. The car is back on the ground on its suspension and all looks well. But i guess i'll find out when it eventually goes for alignment.
Here are some pictures that might help if you are looking to build one...
Old Apr 16, 2009 | 01:02 PM
Camaro0605's Avatar
Car: 1991 RS
Old Apr 16, 2009 | 01:23 PM
Stephen's Avatar
Car: 87 GTA
Originally Posted by Camaro0605
I've gotta ask....Is that an electrical cord, on a wooden frame?
Old Apr 16, 2009 | 01:44 PM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
I think its a rope to pull it because if you pull it at the towers it would break.
But that might just work for my monza race project since I have to repair so much rust (they rusted on the showroom floor) and that would be perfect. But I think I would rather borrow my buddies plasma cutter and get some scrap steel tubes and go to town with the welder. But the wooden one looks like it did the job rather well but I don't have a garage to keep it so it would get wet and warp.
Old Apr 16, 2009 | 01:57 PM
Camaro0605's Avatar
Car: 1991 RS
It's a rope to pull it. We had one on each side. However we didn't move it around much as i didn't trust it. It was fine when it was stationary but the weight on those castors made for a jerky transportation. I think the ropes ended up giving out on us and you can see the straps that we used as a replacement in the other pics.
If you are going to be moving it around a lot then metal would probably be better. Ours was fine but i always hated moving it since it would sway back and forth a little. Having bigger wheels/casters on it would probably help too.
Old Apr 21, 2009 | 07:45 AM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
so was a c clamp all that was keepin it from free rotating?
Old Apr 22, 2009 | 08:07 AM
Camaro0605's Avatar
Car: 1991 RS
Yep. There was a little resistance from the bolt that it pivoted on and the wood rubbing each other, but not enough. A C clamp on each side worked fine.
Old Apr 22, 2009 | 09:42 PM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
At how many points does the rotisserie mount to the body? And where exactly?
Old Apr 23, 2009 | 08:15 AM
Camaro0605's Avatar
Car: 1991 RS
It mounted to the 4 bumper mounting points.
Old Apr 23, 2009 | 05:34 PM
stealtht/a's Avatar
cool. anyone know what a f-body totally stripped like this weighs?
Old Apr 25, 2009 | 02:34 PM
Tehsocks's Avatar
Car: 85 Camaro Z28
Engine: 6.0L LS
Transmission: T56 Magnum
Probably 10 pounds......
its the doors that add all the weight to the car lmfao.
Old Apr 27, 2009 | 09:16 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
My convertible weighed around 300-400 or so pounds, I could pick up the front of the car with 1 hand and the rear was a struggle but I could do it and I am average in size. But it was a vert so I would imagine a hard top or t-top would weigh a little more.
robguitargod1
Jun 3, 2014 08:54 AM
jfl1960
Jan 29, 2014 07:51 PM
camaro_boy123
Mar 23, 2009 04:20 PM
avaspell
Aug 30, 2007 10:22 PM
AaronIROCZ
Mid-West Region
Oct 20, 2005 01:17 PM
