cover removal
Old Apr 16, 2009 | 09:34 PM
Race Wilson's Avatar
Car: 1985 Z/28
Engine: 305 4bbl.
Transmission: auto
Axle/Gears: 3.08
cover removal
Can someone please tell me how to get access to the two screws just in front of the rear wheel that hold up the back of the rocker ground effects? I can see them, just not how to get them out.
Old Apr 16, 2009 | 09:45 PM
watson90z's Avatar
Car: 1990 iroc-z
Engine: 350 tpi
Axle/Gears: 3.23 posi
Re: cover removal
dude i was just wondering the same thing im prepping for paint and dont wanna break it trying to pry on it lol so i need help too
Old Apr 16, 2009 | 11:03 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Re: cover removal
Did you try taking the wheel off?
Old Apr 16, 2009 | 11:10 PM
irocman79's Avatar
Car: 1989 Iroc Camaro
Engine: Stock 350 TPI
Re: cover removal
you need to take your rear interior speaker cover off the whole plastic piece. you will them be able to see the stud and be able to take the speed nut off
Old Apr 17, 2009 | 06:41 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: cover removal
IIRC, you have to remove that entire piece. The access hole is usually covered by a square piece of rubber (a water barrier, I guess).
JamesC
Old Apr 17, 2009 | 07:57 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Re: cover removal
Depends on the speaker system in your car. if you can remove the speaker and or speaker cover and have full open access to the 1/4 panel, reach in and you'll feel the speed nut. If you have insulation surrounding the speaker, you need to remove the plastics to get that out of the opening and then you can reach in. Not all cars have the speaker insulation.
Old Apr 17, 2009 | 10:16 AM
Car: 1985 Z/28
Engine: 305 4bbl.
Transmission: auto
Axle/Gears: 3.08
Re: cover removal
Thanks for all the replies. Mine is a 1985 Z28 and I got to the nut from inside. You have to remove the rear plastic "arm rest" panel below the fabric speaker cover. The nut requires a 7/16 deep well socket. It came off very easy once I got to it.
Thanks and here's to warmer weather!
New2Chevy
Sep 28, 2015 12:35 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
3rdgenparts
Aug 8, 2015 07:09 PM
