Replacing Driver/Passenger Windows
Old Apr 19, 2009 | 04:35 PM
gu1tarjunk1e's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7l L98
Does Anybody know what kind/size of rivets are needed to reinstall the side windows in a 89 Trans am. I have bought the new window, and i know that the rivets need to be drilled out to remove the old window. so if i could get those before i tackle it, it would save time. Also Is there a Write up for replacing the Door Windows??
Old Apr 19, 2009 | 05:14 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: Replacing Driver/Passenger Windows
the only rivets should be ones that hold the regulators to the door shells
use machine screws and nuts to reattach them
Old Apr 19, 2009 | 06:01 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
the rivets were used for speed on the assembly line . machine screws with lock-nuts . good luck .
Old Apr 19, 2009 | 06:03 PM
popballz's Avatar
Car: 89 firebird
the things on the bottom of the window that old the track piece on? your new window didn't come with that? i was able to take the window out with that piece on...
Old Apr 21, 2009 | 07:15 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
I know I'm just repeating what others have said, but stick with nuts and bolts. It makes things much easier if you ever have to do the job again. If you're worried about the nuts coming off, get locking nuts or put a dab of locktite on there.
Old Apr 21, 2009 | 02:53 PM
my89's Avatar
Car: '89 Formula
Engine: 305 TBI
This site covers the installation well: it points out that rivets won't loosen over time. But I suppose lock nuts wouldn't either.
http://www.p71interceptor.com/thirdgen/powerwindows/
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
pfsteichen
Feb 9, 2016 06:59 PM
stalkier
Aug 21, 2015 01:54 AM
Wylecoyote08
Aug 14, 2015 08:28 AM
