engine bay
Old May 4, 2009 | 12:45 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
engine bay
well i have my 85's engine ripped out so i can do my swap,and i would like to clean off the surface rust here and there and paint my engine bay, anyone have suggestions? should i sand blast it? what should i use for paint?
Old May 4, 2009 | 12:55 PM
Scamo-2.8's Avatar
Car: 1989 Camaro RS
Engine: 1990 - 5.7
Transmission: Tremec 3550
Axle/Gears: 9 Bolt - 3:45
Re: engine bay
I kinda think flat black looks good, takes the eye away from the fender wells and focuses more on the engine. I doesn't look as dirty and it's easy to touch up as opposed to body colour, unless the body colour paint of your car is flat black.... lol
Old May 4, 2009 | 01:36 PM
mr_han_solo's Avatar
Car: 1986 Camaro Coupe
Engine: 2.8L V6
Re: engine bay
I DA sanded mine 300 grit, the parts I couldn't hit, I hand sanded 300 grit. Then i used John Deere (yes the tractor) primer for the engine bay. (I did alot of reading up on it, and the primer is pretty much bulletproof, it withstands high heat, completely seals, and dries HARD.) Its a bright yellow which is pretty good when your spraying over it because you know you hit all the spots. After that I sanded it in spots where I over sprayed too much, (and trust me, to get in some of the cracks and crevices expect to put a thick coat in some places). Then I hit the bay with my PPG semi-gloss black. The only picture I have is with my strut mounts still installed and my steering linkage still attached, I have since removed those and hit it with 2 more coats. Hope this helps a little.
http://picasaweb.google.com/rmcole/C...35573243712290
Old May 5, 2009 | 12:23 PM
Chevy8588's Avatar
Re: engine bay
bump?
Old May 5, 2009 | 01:40 PM
TREK's Avatar
Car: 1979 vette
Transmission: th350
Re: engine bay
what ever paint and procedure you use i would top coat it with a semi-gloss paint.
Old May 20, 2009 | 04:38 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Re: engine bay
I did mine body color (White) and it is already looks dirty. Considering a change to flat black.
Orr89RocZ
Apr 25, 2016 08:28 AM
Reddeath210
Oct 6, 2015 08:20 AM
Polo Z03
Sep 10, 2015 06:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
