Replace RPO Sticker?
Old May 27, 2009 | 12:05 PM
chuck_sherwood's Avatar
Car: 86 IROC
Engine: 305 TPI (for now)
Is there a way to obtain the original RPO sheet/sticker that belongs to my 86?
I have come to realize that the center counsil has been replaced and the VIN number and the RPO sheet is not (of course) for my car.
Is there a way with my VIN number to get an original RPO sticker for my 86 IROC?
Old May 27, 2009 | 12:18 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Re: Replace RPO Sticker?
The closest thing I can think of is looking for a build sheet under the carpet, usually on the area above the tank. It will have most of the RPO codes that are not standard on an 86. This may be better fitted for the History board. I don't think you can get it reproduced alothough a banner shop could print it out for you if you scanned in the one you had and typed in the correct info. I had someone that worked for GM send me a copy of the window sticker printed off microfilm so they may have the documentation but finding someone that works for GM that has access is hard. I don't have their info anymore but I ran accross them on this board. That has some of the options listed for the car you could build a deceint list of RPO codes between those two items. The guys on the history board could probably tell you the default codes on the 86 IROC, assuming it is an IROC and not a clone.
Old May 27, 2009 | 12:43 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
http://www.gmmediaarchive.com/ here is a site that you can order history info on your car.
Old May 27, 2009 | 01:24 PM
Car: 86 IROC
Thanks for all the info :-)
I will have to tear into the carpet and follow up with the website you provided!
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
Thornburg
Aug 25, 2015 01:46 AM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
