87 vert GFX on 89 rs coupe?
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Transmission: 700R4,700R4
Axle/Gears: LSD,LSD
i was taking my gfx off my 89 and ended up busting them...im talkin about the rocker molding. I noticed that on the vert gfx there arent any mounting tabs on the bottom...will they work on my coupe?
Re: 87 vert GFX on 89 rs coupe?
Yeah, you can use them. The convertible rocker ground effects are just normal pieces that have had a section removed to clear the added frame connector. Since the pieces are fiberglass you really don't need to attach it from the bottom. The front and rear mounting points along with the screws that go in through the top should be fine.
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
