Difference between front and rear wheels?
Old Jun 27, 2009 | 08:57 PM
OddJack's Avatar
I am waiting for a set of stock 16" wheels to arrive.
How exactly do you tell the difference, you just measure the width?
Old Jun 27, 2009 | 09:06 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Difference between front and rear wheels?
they are usually marked "front" and "rear" might be a small spacer too
Old Jun 28, 2009 | 12:03 AM
leonpiper69's Avatar
Car: 91 mustang
Engine: ls1
Axle/Gears: 3.55 8.8
all the ones i have seen ARE marked front and rear. but i have never seen any kind of spacer. the differance is the offset.
gm stopped having diff (front vs rear) when they went to the 4th gen with the front wheel drive rims. but if you look at a 4th gen you can easily see the diff. the rears sit further inward.
this is just a random pic i found doin a google search, but you can see how the front sits even with the fender and the rear is in more. its the same on a 3rg gen but with the iron and gta wheels they compensated for it.
her's an 85
and here you can see on an 85 with 16 inch wheels the rear sit out furthur
Attached Thumbnails Difference between front and rear wheels?-4thgenoffset.jpg
Old Jun 28, 2009 | 06:37 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
[QUOTE=leonpiper69;4203240...but i have never seen any kind of spacer. the differance is the offset.[/QUOTE]
You can find more info about the spacer in the following link, should you be interested:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Jun 28, 2009 | 09:12 AM
Car: 91 mustang
Engine: ls1
JamesC
i did not know that! but then again i have never seen one with aluminum drums either. neat, learned something new.
Old Jun 28, 2009 | 09:39 AM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
The 91-92 Camaros wheels you are waiting for will be marked "Front" and "Rear" under the center caps.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
kah992
Aug 19, 2015 02:55 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
