Upper door pins, Lower DoorPins or Both?
Old Jun 28, 2009 | 01:50 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
I just picked up a 91 vert, drivers door has a bit of a sag (no surprise). Its not too bad but I figure I might as well fix it as its scraping the groudn FX a little bit, and rattles a bit when driving which I figure is related to the slop in the door pins/bushings.
My Question is I can see when I move the door up and down only the top "pins" shift around abit, should I replace both top and bottom or just the top?
Also with doing these its it just better to remove the door all together (which I have done before on a couple previous 3rd gens...so I am familiar with), or is it more work to remove the door than what is "saved".
Thanks,
Dave
Old Jun 28, 2009 | 02:39 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Re: Upper door pins, Lower DoorPins or Both?
Since the bottom pins are only about $10 it would be a good idea to replace the both. Removing the top pins can be difficult with the door in place as you'd have to slip a grinder of some sort in there to cut the upper pins off. So taking the doors off might be easier.
Old Jun 29, 2009 | 10:36 AM
1Aauto's Avatar
Former Sponsor
I'd recommend repairing both sets as well,they'll both be done,it'll be done right and you can move on to the next thing. If you need a kit to do both doors, shoot me a PM and I'll see If I can get a price for you.
1992 Trans Am
May 10, 2023 07:19 PM
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
