Spray can primer advice
Old Jun 28, 2009 | 11:18 PM
dstss's Avatar
Car: 1992 TA Convertible
Engine: 5.0 TPI
Transmission: THM 700
My TA has been peeling paint for a while. It has several other needs including a new interior, so it is up on blocks until I can afford to fully restore it. In the mean time, I am stripping the entire car before the eventual paint job. I am doing the stripping (using aircraft remover and sandpaper) as I get time this summer. Question is spay gun primer would be best, but as I am working a panel at a time, am I ok to spray can it with an etching primer for now? Or am I just going to have to sand that down later to get a better primer when I am ready to paint. I am going to be putting a lot of time into this and want it right when I get done.
Any advice would be appreciated.
Old Jul 4, 2009 | 11:38 PM
NatesZ/28's Avatar
Car: '00 Regal GS/'87 T.A WS-6
Engine: stock 3800 series II/stock 5L TPI
Transmission: fwd auto/stock 700r4
Axle/Gears: wrong wheel drive/3.23:1 Posi
Re: Spray can primer advice
Im not a fan of etching primer; 2 reasons. 1 its lacquer based and 2 it can cause some problems if its not sealed correctly. Use the correct sandpaper for the paint/primer youre using. There ARE 2 part (hardened) primers in spraycans. Theres a way you open a valve which released the hardener into the can, you shake for 2 minutes and then paint. Eventually the paint turns into a brick in the can so dont crack it open untill youre damn good and ready though. Wear a respirator for this stuff.
Any unhardened primer is just junk and absorbs water, so its actually almost worse that just light surface rust. I had to leave my car in bare steel under a tarp for a month due to a death in he family. a couple hours with a DA sander, wipe down, tack-rag and epoxy primer. She sat in epoxy primer for 3mos with no problems. Epoxy primer is the best way to go for primer.
You COULD wipe the panel down with something like WD40 on a rag to keep the parts from rusting, just make sure you dont SPRAY the stuff on the panel...ALWAYS ON A RAG, and use a degreaser followed by a tackrag before you paint.
I had one of my fenders in bare steel hanging in the garage for a year...with only light oxidizing. If you can keep the parts up off the floor and DRY you'll be fine for a while.
Nate
Old Jul 4, 2009 | 11:41 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Buy your local body guy a lunch or somethin and ask him what his recomendations are. Pro's know quite a bit lol
Old Jul 5, 2009 | 06:35 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Spray can primer is a mistake. I've used it a few times, and depending on the heat of your paint, you can melt it and cause a mess.. I've had runs on previous paint jobs from using it.. For a quick touch up, it's fine, but for serious body work.. Run the other way.. Get a cheap spray gun, you can get them at Princess Auto for 19.95, and a can of laquer primer w/ thinner from $20-30
Old Jul 5, 2009 | 07:24 PM
dstss's Avatar
Engine: 5.0 TPI
Thanks,
I appreciate all the input.
Old Jul 9, 2009 | 12:44 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I despise it when I see this suggestion;
It's not the paint gun that breaks the budget, it's wiring your garage for 220V (contractor/electrician), a couple thousand dollars there (assuming you want to meet local building codes...), buying an air compressor that will run said gun ($1000 or so), air dryers, ventilation in the garage that won't explode, more lighting - etc etc. If you already have that stuff, then you'd be retarded to not just go out and buy a gun, and the $50-$100 worth of paint. Paint and a gun is cheap. The rest is expensive...
Tremclad starts to look better now eh?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
