door hinges
Old Jul 12, 2009 | 03:09 PM
86z28guy's Avatar
door hinges
hey im needing some help replacing my door hinges. i can't figure out how to get the hinge out of the door. is there a way to do it without taking the door off?
Old Jul 12, 2009 | 04:00 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: door hinges
GM replacement hinges require you to un-wire and remove the door to remove and replace the door half of the upper hinges. I sell two aftermarket versions which are easier to install than the GM version, TDS 200370, upper hinge repair kit (non-greasable) $74 or TDS 201370, upper hinge repair kit (greasable) $96. You remove the door and retract it just enough to remove the old bushings and install the new ones. It's all covered in the enclosed instructions.
Lon Salgren
Old Jul 13, 2009 | 01:14 PM
cdoyle's Avatar
Re: door hinges
Lon Salgren
These are well worth it, I redid mine with Ionsal's kits and they work great.
Much better then trying to replace with GM replacements.
Old Jul 13, 2009 | 02:04 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Re: door hinges
How is the install?Pretty easy?Gotta get me some of these.Replacing with GM hinges looks like a major PITA.
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Veaceonee
Sep 29, 2016 08:15 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
codeysabatini
Sep 20, 2015 11:36 AM
