Door weather guard/splash screen??
Old Aug 12, 2009 | 01:28 PM
zride91's Avatar
Car: 1991 Z28
Engine: 383 TPI
Transmission: 700R4 w/2800 stall
OK, 5 years ago when I took the car apart, I remember tearing apart the doors and ripping out this clear(ish) plastic sheet that covered the inside of the door and went right inbetween the door and the interior door panel. I am assuming it was to help protect the cardboard interior door panel...
Now that everything is going back together, I have no idea where to get this plastic sheet. I guess I could always make something, but would like to see if the original part can be gotten still.
Does anyone know if the plastic is still obtainable and/or what it is called so I can look for it?
Any help is appreciated.
If worse came to worse, it will be getting some thick plastic from Lowes and cutting to fit. I would think any glue would work, right?
Thanks.
Old Aug 12, 2009 | 08:22 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Door weather guard/splash screen??
i have used plastic from lowes/home depot with good results . a hot glue gun & razor blades are all you need . good luck .
Old Aug 13, 2009 | 11:34 AM
1Aauto's Avatar
Former Sponsor
I know what your talking about,they're moisture barriers. I don't have a source for them right now. You could probably use the plastic from Home Depot.
Old Aug 13, 2009 | 12:06 PM
mikeiaz's Avatar
I have used heavy guage plastic like you are talking about, works great and no one is going to see it unless you drive around without your inner door panels : ) You can use waterproof duct tape to attach it, I have done this on two different cars, works just fine. I understand that the original sheeting was attached with "dum-dum" a non-hardening sealant made by 3m and Norton that is sold in strips in 100 foot packs - this is the stuff used to seal around holes in the firewall etc.
Hotrodboba400
Dec 10, 2019 07:07 PM
seiplentz
Aug 19, 2019 06:02 PM
LC2 TECH
Interior Parts Wanted
Jan 27, 2016 08:38 PM
Shane87irocz
Sep 22, 2015 06:21 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
