Safest way to remove paint from side effects.
Old Aug 13, 2009 | 01:19 PM
Mailbox Hunter's Avatar
Car: 89 Camaro RS
Engine: 350 TBI
Axle/Gears: 10 bolt/ 3.23 Gear.
Yep title says it all....
Whats the safest way to remove paint from the side effects?
and / or the front spoiler for that matter.
Thanks in advance, -Rob
Old Aug 13, 2009 | 01:28 PM
kthxbai's Avatar
Car: 1985 Z28
Axle/Gears: fourth gen 3.42
Re: Safest way to remove paint from side effects.
sanding... i started with a 150 block and up
Old Aug 13, 2009 | 02:46 PM
Car: 89 Camaro RS
Engine: 350 TBI
Thanks, I didn't know what grit to start at.
Appreciate the help.
-Rob
Old Aug 13, 2009 | 08:51 PM
NatesZ/28's Avatar
Car: '00 Regal GS/'87 T.A WS-6
Engine: stock 3800 series II/stock 5L TPI
Transmission: fwd auto/stock 700r4
Axle/Gears: wrong wheel drive/3.23:1 Posi
320 wet is probably better, you dont want to scratch or gouge the soft plastic. Me? Id scuff it with 600 wet and spray right over the old paint. Make sure you use an adhesion promoter as well; either rattlecan or the stuff you use in a gun
Old Aug 13, 2009 | 08:57 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
They sell a soft bumper paint remover at body shop stores.. Sanding will kill you, especially if they've been painted.. Work smarter, not harder.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
Street Lethal
Aug 14, 2015 08:25 PM
3rdgenparts
Aug 8, 2015 07:09 PM
