T-Bar Replacement
Old Jun 1, 2009 | 02:58 PM
09ZR1's Avatar
Car: 84 Z28
Engine: 305 4bbl
T-Bar Replacement
was wondering how involved replacing my t-bar can get. Shoot me some lines and let me know.....Thanks!
Old Jun 1, 2009 | 09:16 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Re: T-Bar Replacement
Replacing the T- bar is the easy part, if your already planning on replacing your seals. Trying to save the old seals during replacement would be a challenge.
Old Jun 1, 2009 | 09:21 PM
popballz's Avatar
Car: 89 firebird
is there an easy way to remove it with out bending it?
i got mine off....but its really beat up now. so i gotta find a new one at a junkyard or something, but i don't wanna ruin another one trying to get it off
Old Jun 2, 2009 | 03:01 PM
09ZR1's Avatar
Car: 84 Z28
Engine: 305 4bbl
yeah but how do they come off though? Mine looks like its welded and a buddy of mine is saying his is bolted on??
Old Jun 2, 2009 | 03:07 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
Mine's rusted on, lol.
Just joking.
Old Jun 2, 2009 | 04:52 PM
popballz's Avatar
Car: 89 firebird
mine just had a huge amount of that glue, black, sticky stuff on it. after the 5 or so screws on each side.
Old Jun 2, 2009 | 05:26 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Remove the three bolts from the outer edges, then remove the two (I think it's just two IIRC) hidden ones on each side under the weatherstripping.
Pull up GENTLY on the bar. It is glued on at the factory at both ends, but not with anything super-strong. Take your time when pulling on it. It is thin metal and WILL bend if you pull too hard. It will release if you keep light constant pressure on it.
Be sure you have removed ALL of the screws or you will demolish it.
Old Jun 2, 2009 | 05:30 PM
chris.niemann84's Avatar
Car: 1985 IROC Z28
Engine: L98 - 350/650 Holley DP
Axle/Gears: 3:83 Full Spooled
don't mean to sound stupid, but just to make sure ya'll are talking about the same thing as i'm thinking, can someone post a picture of the piece that we are talking about... going by the explanation i'm assuming it is that really thin piece of sheet metal that goes between the t-tops to hold the glass down on the insides... i hope i'm right anyway... LOL thanks guys
Old Jun 2, 2009 | 09:30 PM
Car: 86 T/A
Engine: 5.0 TPI
Almost... That thin part you see is part of a much larger part. When you get it off it will be as long as the t top and about 10 inches wide. It covers that whole center of the roof and the seals set into it.
Old Jun 2, 2009 | 11:08 PM
popballz's Avatar
Car: 89 firebird
ummmmm, mine had a little more glue then that. basically the whole underside was filled with glue, someone might of done it after they owned it thought, i do not know, i tried light pressure and i tried hard pressure, both didn't work, i used screw drivers and putty knife and small crowbar to take it off
oops, i didn't hurt the car, but this bar is pretty beat up in other words, if you don't have a replacement on hand, be very very gentle
Old Jun 3, 2009 | 11:27 AM
gcgarner's Avatar
Sounds like a previous owner did that. I have taken two off and neither were much trouble. They both had just a little bit of adhesive on either end.
Old Aug 14, 2009 | 03:31 PM
09ZR1's Avatar
Car: 84 Z28
Engine: 305 4bbl
im not worried about damaging it, its rusted all to hell but oh well thanks for all the input!!!
Out-Cast
Dec 31, 2015 04:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
