drivers side mirror rattling
Old Aug 30, 2009 | 01:36 AM
hotrodjames's Avatar
Car: 89 IROC-Z
Engine: 5.7 liter
Axle/Gears: Stock
MY drivers side mirror is MAKING A RATTLING NOISE. ANY IDEAS WHATS LOOSE? CANNOT STAND IT ANYMORE
Old Aug 30, 2009 | 08:28 AM
Firebat's Avatar
Re: drivers side mirror rattling
If its the whole mirror housing unit, then the 2 bolts that hold it down probably need to be tightened. Just everyday vibrations from driving on the road may have loosened those bolts. You have to take off the door panel. Then tighten them with a 10mm socket or wrench. There also should be a somewhat thick hard plastic gasket in-between the mirror housing and the door panel.
Old Aug 30, 2009 | 09:31 PM
DeathMetalTony's Avatar
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
Yeah my passenger mirrior had the same probloem as you drivers mirror I had to take of the interior panel and take it easy on it too, lol. Well good luck bro.
Tony.
Old Sep 3, 2009 | 02:42 PM
Car: 89 IROC-Z
Engine: 5.7 liter
Axle/Gears: Stock
My entire mirror is not loose, just the mirror part is rattling. is there no way to remove the mirror without breaking it?
Old Sep 3, 2009 | 04:01 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
If you angle it all the way in, or down you'll see a small cross shape that holds the mirror in the center. If you take a screwdriver and GENTLY pry the mirror loose, then slowly pull the two drive posts out of the mirror motor. Usually these posts wear and let the mirror move around a little and rattle.
Old Sep 3, 2009 | 11:10 PM
DANNY25SS's Avatar
Car: 92' Formula T-Top
Engine: L98 With Custom CAI
Transmission: BUILT 700R4 with B&M Mods
my whole outer door skin is loose by the mirror it bounces along... that common or something worse goin on?
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
LittleFranks
Sep 17, 2015 12:22 PM
kkirch15
Interior Parts Wanted
Aug 28, 2015 10:03 AM
timonator
Aug 11, 2015 09:56 PM
89FormulaMan
Aug 10, 2015 10:01 PM
