Small dent on quarter panel crease line
Old Sep 3, 2009 | 08:47 AM
whitedevilTA's Avatar
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Hi all. Just looking to get some tips and pointers here. I am trying to fix a pretty small dent on my rear quarter panel. Unfortunately it's right on the body crease, and I've got the area perfect, but that friggin crease is not to my liking yet. It doesn't flow like factory, though it is very close. I'm using autobody icing and a small 3.5x5 inch block to try to get it straight.
Any tips on anything different to try? I am painting this car and have it stripped to a bare shell right now and this has to be perfect!
Old Sep 3, 2009 | 10:47 AM
toomany's Avatar
Re: Small dent on quarter panel crease line
A trick I use when do a hard line is put some masking tape (3m green or even blue) on the line. Then work above the line. After some time take the tape off and put another piece on so you can work the bottom side.
Old Sep 3, 2009 | 11:21 AM
Stephen's Avatar
Car: 87 GTA
To do a body crease, your gonna need a "wedge" block & get to that area from the back side.
Get the metal as close as you can, then finish it off to perfection, with a SKIM coat of some quality body filler.
Old Sep 3, 2009 | 12:43 PM
Car: 1986 Trans am
Engine: 5.3 LM7
Thats actually a great idea! Thank you very much for that. I'll try it as soon as I get home from work.
And Stephen, I can't explain the situation very well, but it's such a minor dent that you can't even really feel it from the inside of the quarter panel, and it's in a spot where getting a block in there would be hard, or else I would have loved to bang it out. I can't stand the thought of having bondo on my car, but I want it to have perfect lines. Thank you for the idea though!
Old Sep 3, 2009 | 02:58 PM
howy03's Avatar
Car: 1985 Pontiac Trans Am
If its that small of a dent using a little glazing does not qualify as bondo.Its used on all cars.You can also eliminate most tiny dents and ripples with high build primer. Then block sand it down
Old Sep 3, 2009 | 04:34 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
you NEVER use 2k primer as a filler (not even for a small dent) because they shrink with heat. On small dent 1/8" or smaller, you can use glazing putty, and as TOOMANY said use masking tape to achieve the crease
Old Sep 3, 2009 | 10:37 PM
Car: 1986 Trans am
Engine: 5.3 LM7
Well, tried the tape trick when I got home and sure enough the crease line came out PERFECT!! Thank you so much guys. This car is coming along awesome now and I can't believe I've done everything myself so far. Feels good!
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
two-if-by-sea
Exterior Parts for Sale
Sep 13, 2015 06:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Exxon Limited
Aug 9, 2015 08:13 PM
