pulling ground FX....anyone done it recently?
Old Sep 17, 2009 | 11:55 PM
razman340's Avatar
Car: 1985 Z28
Engine: 305ci 4barrel
Transmission: 5-speed
1985 Z28....gonna re-paint my ground effects. started trying to pull them off this evening. has anyone here done this recently? i started on the RH side, door and RH lower. pulled all of the visible hardware off.......both pieces are still pretty snug. on the door strip, do i have to pull door panel and get to more fasteners from behind? on the lower RH section, do i have to pull front wheel well housing to get to more fasteners? does anyone know what the tricks are? how bout the front and rear sections? more suprises in store for me? thanks for any info......rick
Old Sep 18, 2009 | 11:12 AM
Iroc-Z28Man's Avatar
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
Re: pulling ground FX....anyone done it recently?
Lets see here. It's actuallly a real pain to take them off. ON the front of each side gfx were the Z28 badge should be there was two screws on each side. on the back of each gfx there is a stud coming off the gfx that has on of those little nuts on it. But the only way to acess it is to take the interior panel out that is right behind the door. behind that there is an acess hole with a peice of rubber over it (idk why). in there you'll find the that nut. Also i don't know if you saw them but there are more screws underneath on the side gfx, like under the rocker panel. If you want me to i can see if i can post pics of were this stuff is over the weekend.
Old Sep 18, 2009 | 11:17 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yes.
JamesC
Old Sep 18, 2009 | 12:19 PM
razman340's Avatar
Car: 1985 Z28
thanks guys, i appreciate the help! IrocZ28man, i would love it if you could post some pics of where some of these fasteners can be found. so far, i am starting with pulling the side FX. i did pull all of the screws under the car by rocker panel area, and the screws that are in the door jam area, but the front and rear of the FX seems to be still held on by more hardware. i guess i have to pull the door panel to get to the rest of the fasteners on the smaller strip piece.......
if anyone has some pics or more hints on pulling the ground FX, i would appreciate your input also! thanks, rick
Old Sep 18, 2009 | 04:59 PM
Engine: 350TPI/ S50
in the first thumb nail. the red arrow is pointing to the interior panel that you will need to remove to get to the hole picture in thumbnail 2( outside view). thumbnail3 is what the acess hole looks like from the inside after you remove the interior panel. once you get to that acess hole then you can remove the nut from the stud on the gfx and the back should be loose. I'll post the pics for how to remove the front sometime tonite. i Hope these help
Attached Thumbnails pulling ground FX....anyone done it recently?-100_1613.jpg   pulling ground FX....anyone done it recently?-100_1614.jpg   pulling ground FX....anyone done it recently?-100_1612.jpg
Old Sep 18, 2009 | 05:06 PM
razman340's Avatar
Car: 1985 Z28
thanks a bunch! this helps alot, now i can pull the panel and get to the stud,
on the same ground FX, can i get to the front hardware holding it in place without removing any panels?
keep the pics coming! this helps me alot, and i apprecitate it! rick
Old Sep 18, 2009 | 07:18 PM
Engine: 350TPI/ S50
The screws that hold the front of the gfx are found underneath the z28 emblem on the Gfx. it should pop off if you use a screw driver to carefully pry it off. under that there are two screw pointed out by the red arrows in thumbnail. And as far as i can remember that is all that hold the front on.
Attached Thumbnails pulling ground FX....anyone done it recently?-100_1616.jpg   pulling ground FX....anyone done it recently?-100_1615.jpg
bryan623
Mar 22, 2021 06:43 PM
hectre13
Aug 26, 2015 08:17 AM
evan555222
Aug 22, 2015 07:14 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
