Question about a hood
I got a hood off a 89 firebird to put on my 92, the hood has a slight cowl looking slope on the driver side, thought at first it was for a tachometer, but it seemed to big of a hole
i found a picture off google images of a guys firebird with the same hood,
like to know if this hole need to be sealed or if it can be left opened
Car: 1985 Chevrolet Camaro
Engine: V8 lb9 i believe..
Axle/Gears: 10 bolt posi
Re: Question about a hood
it can be left open. it can be sealed. its up to you. i dont KNOW the functional use, but i can assume that air passing under the nose of the car can vent out the top of the hood thru that hole.
Car: 87 GTA
That is the stock "Formula" hood.
In some years (carb'd) it was designed as an actual air cleaner inlet, to draw in cool air from the outside, from the cowl.
Open or closed, your choice.
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Iroc8t8
Aug 26, 2015 08:14 AM
