passenger side fender removal: I'm stuck
Old Sep 26, 2009 | 01:05 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
Yes I searched.
Breaking down the front end, got the front bumper and spoiler off, hood removed, got all bolts on passenger fender removed EXCEPT the last ones down low, behind the front wheel.
I see two bolts where the front of the gfx attaches (got the first one) and another bolt further back that I cant seem to get too.
Do I have to remove the whole passenger side gfx to get this one? Or is there something else I should know?
I dont know if it makes a difference, but its a convertible and I have the factory bracing along the passenger side as well.
Old Sep 26, 2009 | 01:38 PM
vampyrico's Avatar
Car: 1985 Chevrolet Camaro
Engine: V8 lb9 i believe..
Axle/Gears: 10 bolt posi
Re: passenger side fender removal: I'm stuck
there should be two bolts on the bottom of the car near the jack lift area. if you cant see them and you suspect the ground fx are in the way. then they should be removed
Old Sep 26, 2009 | 04:40 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
A lot of people jack the car from the fender area and it gets f*ed up. There should be two decent sized bolts there, but the flange they mount to probably got bent. You might have to take the ground effects off but I don't think you do.
redmaroz
Apr 25, 2017 07:14 AM
corlando52
Interior Parts Wanted
Aug 24, 2015 11:32 AM
Cameeeero
Aug 20, 2015 03:06 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Street Lethal
Aug 14, 2015 08:25 PM
