Need help getting rear bumper absorber off!
Car: 89 Formula 350
Engine: 5.7 TPI
I can't get the top nuts off holding the rear absorber. The bolts were lightly pressed into the absorber and now they're spinning with the nut. I can't reach the bolts with vise grips, its too narrow for a cut-off wheel. Any ideas as to how to get these off?
Car: 87 GTA
Re: Need help getting rear bumper absorber off!
Not sure how deep or narrow that space is. But you could stick weld a simple single tack-weld in there, to hold the bolt from moving.
I suppose you could give JBWeld a shot, if you can reach it down in there.
Car: 89 Formula 350
Engine: 5.7 TPI
I thought about that but I only have a MIG and the torch has too much of a curve to get it up there.
Car: 87 GTA
Yeah. I have a MIG too & knew there was no way the gun would fit in there, along with a hand to pull the trigger, so I didn't bother suggesting it.
Maybe....You could use a hole saw to cut an opening to fit the gun nozzle through there, and tack it? You could always MIG the hole shut again, after you were done.
Car: 1988 convertible Z28 I think
Engine: 30 over 350 carbed and HEI
Transmission: T5 5speed
Axle/Gears: 9bolt 327posi disk brakes
I really don't have a suggestion on how to get yours apart. I just removed mine two weeks ago and all eight bolts spun in the housing. Mine was rusted and needed replaced anyway. I had to cut the bumper into pieces just to grind the bolt heads off. They really are buried. I know I wasn't any help, just wanted to say I feel your pain.
Car: 89 Formula 350
Engine: 5.7 TPI
Yeah, looks like I have to get medieval.... I thought it was going to be easy.
Car: 86 T/A
Engine: 5.0 TPI
Looks like you could get a sawzall up in there to cut the head off. At least the one in the pic is loosened enough to have a small space where you need to cut. Don't know about the rest.
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
put a pry bra up in there and spin the nut till it snaps into place and hold it witlh the pry bar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
I had the same problem when I was trying to remove mine when I got my car painted, but I just ended leaving it on it was to much of a hassle although it is awfully rusty
Car: 1984 Z28
Engine: L69
Why not attack it from the bottom side? Extend the shock and cut the shaft with a cutoff wheel. Then you should be able to pull it out from the top.
Hope this helps.
Mike
Hope this helps.
Mike
Car: 1987 Pontiac GTA
Engine: 350tpi
Transmission: t56 6 speed
Axle/Gears: 3.70
do u think u have enough room to get a regular torch at the nut or the head and cut it off with that
1992 Trans Am
May 10, 2023 07:19 PM
