hood struts
Car: 82 z28
Transmission: auto th350
Axle/Gears: stock
hood struts
Hood struts for a fiberglas hood are 3x more money, than for a steel hood.If you put on the ones for a steel hood would it break the plastic hood?
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Re: hood struts
It's not the weight of the hood, but the strength. I've seen fiberglass hoods fold over when standard struts are used. You can get by cheap (or free) by finding someone that has a used set that's partially worn out.
Re: hood struts
HI Steve,
Those struts are all built with different retentions, so that if you have a fiberglass hood it would have less retention than the struts for a steel hood,because the steel weights more and it takes more force to push it open.
Here's a link to them on our site,their all broken out pretty well with option choices vrs correct retention.
Camaro Hood & Hatch Struts
Car: 82 z28
Axle/Gears: stock
Re: hood struts
So is an SMC hood the same as a fiberglas hood and use the same struts? I am currently working on my new project(82 Z-28)
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
