Hood Scoop Leaks??
Old Oct 13, 2009 | 07:39 PM
radar1232's Avatar
Car: 1983 Firebird, 1989 Firebird
Engine: 2.8L V-6 2bbl, 305 V-8 4bbl
Transmission: 200C Metric, 700R-4
Axle/Gears: Stock
Hood Scoop Leaks??
Ok Gurus, here is my problem I am getting water on my air cleaner and it is making it rust. I have included pics to assist, I want to think I am missing a piece but I am not sure I know older birds but this is my first Third-Gen.
Attached Thumbnails Hood Scoop Leaks??-dscn1094.jpg   Hood Scoop Leaks??-dscn1095.jpg   Hood Scoop Leaks??-dscn1099.jpg
Old Oct 14, 2009 | 09:24 PM
radar1232's Avatar
Axle/Gears: Stock
Re: Hood Scoop Leaks??
Anyone got any ideas on this?
Old Oct 15, 2009 | 03:18 PM
hedberg667's Avatar
Car: 1989 GTA
Engine: 5.7 350
You have the formula power-bulge hood right? If so my buddy had an 88 formy with the same hood and he had a blocker plate put into the slit. Thats the drawback of an open hood so to speak. It brings in more air but it also lets in the rain
Old Oct 16, 2009 | 08:00 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
Oh geeze, should I close mine then? It runs every day so I assumed rust wouldn't be a problem because it lands right on the distrib. cap cover. (TPI)
Old Oct 17, 2009 | 07:31 PM
RedRokkit's Avatar
Car: 1984 Trans Am, 1986 Fiero SE
Engine: 5.0 H.O., 2.8
Transmission: T5, M4 Muncie
Axle/Gears: 3.73 disc posi, CAVALIER AXLES!!
The "Power buldge" Hood that you have,from the factory had a piece that bolted to the underside of the hood, that closed the scoop off when the engine was cold. I forget what they call it, but it would keep the water out..Ill see if I can find a picture of one.....Ive still got mine but I took it off.
Old Oct 17, 2009 | 07:40 PM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
Yes, there should definitely be something covering the opening in the hood. The '87 and later cars has a black off plate on there covering the hole. The 82-84 cars had a screen covering the hole and an air box mounted to the underside of the hood that matched up with the air cleaner on the engine.
However, if you have a 2.8 V6 in your car that isn't the original hood because you couldn't get that hood with a V6. You need to get an '87-up block off plate for the opening because there isn't an airbox for V6 cars. We may have one for you if you need it.
Old Oct 18, 2009 | 08:51 PM
radar1232's Avatar
Axle/Gears: Stock
I looked on your site and did not find it. How much would it set me back????
Old Oct 18, 2009 | 10:46 PM
Former Sponsor
Car: Too many
I'd have to check and see if we have one but it would run $15 shipped.
Old Oct 19, 2009 | 11:01 PM
radar1232's Avatar
Axle/Gears: Stock
Ok no probs keep me informed. Got my accountants permission to buy it.
Hotrodboba400
Dec 10, 2019 07:07 PM
bamaboy0323
Sep 12, 2015 07:14 PM
blackandblue02
Sep 10, 2015 08:19 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
