Can you chemically strip a bumper?
Old Oct 19, 2009 | 04:50 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
My SEARCH feature isn't working and I'm looking to see if you can strip the paint off the nose and bumper off the third gens using aircraft stripper or something like that? I've got an extra nose I can strip and prime to get ready to go on the car. Is this just a sanding only type deal?
Ken
Old Oct 19, 2009 | 08:03 PM
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
Re: Can you chemically strip a bumper?
Not sure why paint stripper wouldn't work. I believe sanding is more preffered and easier since you basically just scuff up old paint. Does your bumper have severe spider cracking? That would probably just require deeper sanding.
Old Oct 19, 2009 | 08:13 PM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
I've used aircraft stripper on mine but be careful. Do small sections at a time because it will eat the bumper if left on too long.
Old Oct 19, 2009 | 08:14 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I tried using paint stripper when I was doing the bodywork on my old 83, but it wound up not really working well. Rather than cleanly taking the paint off, it just took off patches, and bubbled the hell out of it. I wound up sanding it down anyways. Also, don't get it on any plastic, such as the license plate light lens, etc. It will eat it in a hurry.
Old Oct 19, 2009 | 10:24 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
I would just sand it. If it has any spider cracking maybe use some glazing putty as well after sanding and sand the putty smooth before primer. A good filler/sandable primer will be fine after sanding. I wouldn't use stripper on them...not that you can't if you're careful I just don't see the need.
Old Oct 20, 2009 | 06:36 AM
remltr's Avatar
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
Yes, got to your local autobody supply, they sell bumper stripper. Works pretty well.
mcfastestZ28
Oct 5, 2015 07:12 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
