FUEL DOOR ALIGNMENT
Old Nov 8, 2009 | 08:32 PM
j79z28's Avatar
FUEL DOOR ALIGNMENT
I just removed the fuel door assembly to remove the gastank. Upon reinstallation, I can't seem to get the fuel door to sit flush with the body, or open without slightly rubbing the quarter panel. It does not look like there is any room for adjustments. Any ideas on how to make the fuel door fit flush with the quarter panel? Thanks!!
Old Nov 8, 2009 | 09:10 PM
toomany's Avatar
Re: FUEL DOOR ALIGNMENT
Real common problem. So much so, there is a tech article about it.
https://www.thirdgen.org/rubbinggasdoor
Old Nov 8, 2009 | 11:38 PM
ThePain's Avatar
Car: 1992 RS
Transmission: Automatic
Awesome! Mines rubbing too.
Old Apr 13, 2016 | 02:59 PM
88gtadan's Avatar
Car: 1988 Pontiac gta
Engine: 5.7 tpi
Axle/Gears: Borg Warner 3.27
Cool
Old Apr 22, 2016 | 06:05 PM
82tarecaro's Avatar
You could be missing the gasket that goes under it.
1992 Trans Am
May 10, 2023 07:19 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
AkDrifted
Aug 17, 2015 07:45 PM
