Door Trim
Car: 1990 Trans am GTA
Door Trim
Does anyone know how to remove the trim on the middle of the outside of doors? I figure that they are either held on with glue or bolted.
Car: 89 Trans Am (under construction)
Engine: 350 tbi
Transmission: 700 r4
Re: Door Trim
The body side moldings are held on with some kind of adhesive. A heat gun might come in handy. Keep in mind the area underneath the moldings may be riddled with little dents from door dings (atleast mine was).
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: Door Trim
there is adhesive remover you can buy from autoparts stores that you squirt on there and it dissolves the glue...
Re: Door Trim
All of the OEM door bumpers are peel and stick. It was VERY popular in the 80's to remove the stock pieces and have aftermarket replacements installed. Some of the aftermarket replacements have a steel channel that's riveted to the door every 6" or so, then a rubber strip is slipped into the channel.
The stock ones can be removed just gently peeling them back off, but they'll probably leave a mess of very sticky durable molding tape. The aftermarket parts will have to have the rivets drilled out, and they might have to be peeled off too.
1Aauto
Sponsored Vendors
24
Mar 27, 2018 11:59 AM
IROCZDAVE (88-L98)
Sep 17, 2015 07:43 AM
