t-top leak
Old Dec 5, 2009 | 10:32 AM
PetesPonies's Avatar
t-top leak
Have 84 TA I 'm working on. Left side t-top leaks at the rear. What is the best replacement weatherstrip to use? Who makes it?
Old Dec 5, 2009 | 04:54 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Re: t-top leak
the gen 2 GM kit is getting harder to find. iv heard word its not in production anymore so my next choice would be to check with 1A tony in the body section. there is a door sweep thread going and he is very involved in the product. i may be going with a set of theirs.
HAWKS may have the gen 2 kit still. the gen 2 kit has lil cups that the top seal meets up with so when /if you get a leak the lil cup catches it and it directs it into a drain tube that runs thru the seal. the standard set lile comes stock on your car is the standard ol slice tip version.
as for your leaking, first make sure the top is pulling down enough/correctly. roll the window down and kinda firmly wiggle up and down on the top. there are adjustments behind the trim to pull the glass tighter and this may be your issue.
heres a link to that thread and you can reach Tony from this thread for your seals.
https://www.thirdgen.org/forums/afte...ow-sweeps.html
Old Dec 5, 2009 | 10:53 PM
Re: t-top leak
Thanks for your help . . . . HAWKS ????
Old Dec 6, 2009 | 02:26 AM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Re: t-top leak
HAWKS third gen parts. they are a sponsor of this site.
Old Dec 7, 2009 | 08:55 AM
1Aauto's Avatar
Former Sponsor
Re: t-top leak
The metro seals are good,and the GM (of coarse) work well too,they're just more money.
When you replace them,just take your time cleaning up the old pieces of weatherstrip and use 3M adhesive to glue them back in.
Also do a test fit before gluing them in,It'll give you an idea on how to piece everything together when you do apply the glue.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 22, 2015 08:28 PM
1Aauto
Sponsored Vendors
Sep 22, 2015 03:39 PM
blackandblue02
Sep 10, 2015 08:19 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
