How to fix a warped front bumper pocket? PIC Inside
Old Dec 7, 2009 | 06:16 PM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
I picked up a front bumper the other day, noticed when I got it home there was a high spot on the bumper pocket area, like a small buldge. Is there any way to fix this as the rest of the bumper is good? It is too big to sand flat IMO. Any help would be appreciated.
Mike
Old Dec 8, 2009 | 09:57 PM
astrosurfer's Avatar
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
Re: How to fix a warped front bumper pocket?
a pic would be a huge help here.
showing the damage will get you great help from the knowledgeable guys here.
from the description I'm unsure which part of the bumper you are referring to.
Old Dec 19, 2009 | 04:30 PM
Camrs89's Avatar
you can make out the high spot right on the edge of the drivers side headlight pocket, id say its actually up a 1/8 of an inch maybe from where it should be. Any ideas how to fix this because the rest of the bumper is mint.
Old Dec 19, 2009 | 04:33 PM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
i have the same problem, theres a high spot on the pocket, and the driving light is covered, well half covered.
from what i was told was to heat it up and let it sit. someone else may want to chime in though.
Old Dec 20, 2009 | 09:06 AM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Re: How to fix a warped front bumper pocket? PIC Inside
Heat it up with a heat gun, then carefully work it back down with a wooden hammer handle (the end). You will probably need to keep it worked down while you cool the bumper with a wet rag. Then sand it smooth and apply a little filler (like polyester glazing putty), if it's needed.
Old Dec 20, 2009 | 10:15 AM
howy03's Avatar
Car: 1985 Pontiac Trans Am
It is easier off the car I heated mine up with a heat gun slowly and then clamped some small pieces off plywood to hold the shape while it cools.
Old Dec 22, 2009 | 08:46 AM
Camrs89's Avatar
Thanks 86blackiroc, Ill give it a shot
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
LittleFranks
Aug 20, 2015 03:55 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
