1985 Camaro Sport Coupe Ground Effects
Old Jan 16, 2010 | 03:46 PM
RJ_Moore's Avatar
Car: 85 SC and 87 IROC Both T-Tops
Engine: 305 V8 H Code and TPI F Code
Transmission: 700R AT/OD and 5 Spd.
Axle/Gears: 7.625
Hello, I have an 85 Camaro Sport Coupe, and need to know what I need to upgrade my base 85 Camaro Sport Coupe to have ground effects? What will fit, and what changes if any do I need to make, other than adding extensions?
Richard.
Old Jan 20, 2010 | 06:19 PM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
Re: 1985 Camaro Sport Coupe Ground Effects
It's not too hard to add ground effects to your car. The rocker ground effect pieces have a bracket welded to the body for support but you could bolt them on as well. All you need to do is drill some mounting holes for the door and rear quarter pieces and bolt them on. You'll also need to change your front and rear bumpers but they will be direct bolt ons.
We have most of the pieces you need available on our site if you're interested. Thanks!!!
Old Jan 20, 2010 | 07:31 PM
captain.spauldi's Avatar
Car: '86 Camaro
Engine: 2.8 V6 TPI
Transmission: 5 spd man
I'm also in the same boat with my '86 SC, Does your model have the 3 intake vents on the nose RJ? I bought my camaro with the intension of putting z28/iroc ground effects on but realised to put something like this on: http://thirdgenranch.com/-strse-540/...per/Detail.bok would compromise the 3 intake vents?
Old Jan 20, 2010 | 07:57 PM
Drew's Avatar
GFX are more common then not. For the most part they're cosmetic and dead weight. If you really want ground effects, buy a RS, Z28, etc.
Old Jan 21, 2010 | 06:05 PM
Car: '86 Camaro
Engine: 2.8 V6 TPI
while we're on the subject does anyone have any pics of their sports coupe with added ground effects? would love to see some.
Cheers
Old Jan 21, 2010 | 06:13 PM
Drew's Avatar
Do the swap right, the end result is a car that looks like any other RS or Z28... Do it wrong, you end up with a goofy looking frankenmaro. If you want to see how goofy GFX look tacked onto a Sport Coupe, search some of the companies that make aftermarket GFX. They've usually got several pics of cars finished with their products.
Old Jan 21, 2010 | 06:43 PM
RJ_Moore's Avatar
Axle/Gears: 7.625
Yes, it is the stock SC grill, no fog lights. Richard.
Old Jan 22, 2010 | 06:59 AM
Car: '86 Camaro
Engine: 2.8 V6 TPI
So if you wanted to put a z28/iroc bumper on the front, surely you would have to modify the air intake, as from what I can see the 3 cents on the nose feed it? I am being stupid? is there an easy way to do the swap? By the way Drew, my camaro already looks like a frankenmaro, the dude I bought it from just riveted a z28 lower chin spoiler to it and did a very poor job! it looks ghastly at the moment!
Old Mar 25, 2011 | 10:35 PM
Project86B4Z's Avatar
Car: 85 camaro RS RIP\ 86 IROC-Z :)
Engine: 2.8 MPI V6\ carbed LO5 5.7 v8
Transmission: 700r4 auto
Axle/Gears: 3.42\ posi 3.73
No need for the nostrils the dual snorkel will breathe easily with the z28 nose the air is actually pulled through grille...infact the snorkel set up is actually on some of the tuned port IROC's.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Fronzizzle
Aug 17, 2015 02:52 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
92firebirdchris
Aug 14, 2015 11:56 AM
