cowl hood scoop
Old Jan 17, 2010 | 04:46 PM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Axle/Gears: disk rear, 10bolt.
cowl hood scoop
i am lookin to put a cowl hood scoop on my 83 camaro. i have the fiberglass hood but it has the hole where the air cleaner is comming out. so i need some imput or ideas.
ive looked at jc whitney's cowl Part#wp863810 it is 49 1/2long 22wide 2 3/4 tall
or the ebay L - 47.5", W - 22" (26" w/ flange), H - 3" (inches).
any ideas on what i should i use?? or is there any other options out there?
Old Jan 17, 2010 | 06:16 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: cowl hood scoop
the problem with adding a glass cowl to an existing hood is cracking. Over time the connection you make will begin to crack, or it can even tear off at speed. The best bet would be to saveup and buy a 1pc cowl hood. They pop up used ever now and again for a decent price.
Old Jan 17, 2010 | 06:34 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Re: cowl hood scoop
If the hood is fiberglass and your scoop is fiberglass you should be fine. Make sure to bond the scoop really well and put a few layers of mat on the inside of the joint to add strength. Use as little bondo as possible.
take your time with it. I've built a few fiberglass hoods and really screwed up a couple by rushing.
Old Jan 17, 2010 | 08:27 PM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Re: cowl hood scoop
Ive done it a ton of times... i will sand down the hood and inset the cowl and ues fiberglass resin and only use a little bondo and i will lay a few layers inside of fiberglass. and use revits i was jsut wondering if any one has any imput on which cowl to use???
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
