rebuild of my 91. "god i hate rust" !!
Old Jan 24, 2010 | 07:55 PM
1bad71's Avatar
Car: 91 camaro z28
Transmission: turbo 400
Axle/Gears: 9/bolt
just picked up this 91 z28, looked like it sat in a field or was under water for a while!!
the whole front suspension and under carriage had been sprayed with undercoat to hide the rust. and both front fender mount/pinchwelds had been crushed and rusted out.
i removed the entire front end and subframe, and sandblasted it all and then epoxy primed it then painted all parts with chassis black. i also completly cleaned and sanded the front engine/frame assembly and sealed and repainted it also.
the worst part was the pinchwelds! i had to cut away the whole corner, and remove all the rust and then re-weld it back into place.
here is some pics of what it looked like when i got it, and some repair and then painted shots. can't wait to get it back togther, and drive it again!
[IMG]http://i662.photobucket.com/albums/uu344/1bad71/100_0917.jpg
[/IMG]
Old Jan 24, 2010 | 07:57 PM
1bad71's Avatar
Car: 91 camaro z28
Axle/Gears: 9/bolt
Re: rebuild of my 91. "god i hate rust" !!
couple pics of the engine bay also.
Old Jan 24, 2010 | 09:37 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Lookin pretty slick, keep up the good work!
Old Jan 24, 2010 | 09:45 PM
iggy1991's Avatar
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
nice work. Im in the process of doing that to mine. what kind of paint did you use?
Old Jan 24, 2010 | 09:47 PM
M G Brewer's Avatar
Car: 1988 IROC-Z
wow, looks great and is motivating me haha
Old Jan 24, 2010 | 10:27 PM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
That really looks nice. I know you have a lot of hours in that. The paint job looks great.
Old Jan 25, 2010 | 08:32 AM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
hmm... The more I see these all black engine bays the more I like them!
Old Jan 25, 2010 | 12:39 PM
1bad71's Avatar
Car: 91 camaro z28
Axle/Gears: 9/bolt
it's called chassis black. it's a premixed enamel, all you have to do is add hardner. it is very durable, have used it on a couple of cage and undercarrige jobs.
Old Jan 25, 2010 | 12:44 PM
1bad71's Avatar
Car: 91 camaro z28
Axle/Gears: 9/bolt
i painted the firewall factory color after i pulled the a/c, but it just didn't look that great! i think it looks cleaner, when the engine bay is gloss or semi black.
Old Jan 27, 2010 | 01:33 PM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
I had a 74 Malibu that I painted the engine bay gloss black. It really looked nice.
Old Jan 27, 2010 | 02:13 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
WOW, Im surprised, your car will last forever. My rider is rally, so dirt and scratches are my style, but rust is crushed .
Old Jan 27, 2010 | 08:38 PM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
Nice work, at least it looks super clean on the outside.
Old Jan 27, 2010 | 08:58 PM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
nice! i'm working on my 91 Trans Am convertible now as well. But I don't plan on going as deep as you are lol.
sammy52401
Nov 11, 2015 07:20 PM
Fanatic1074
Oct 2, 2015 03:47 PM
bschmale66853
Sep 30, 2015 08:11 PM
Twinn Engines
Sep 25, 2015 06:27 AM
Twinn Engines
South East Region
Sep 25, 2015 06:25 AM
