Had a question about door removal.
Old Jan 30, 2010 | 07:45 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
My current door passenger door isn't flush with the body at all. A friend of mine is parting out his '90 Camaro ( mine is a '91) and he said I could have his passenger door. Both of ours have the power window,door locks,etc... and my question is how to remove the door. More precisely, since the wires for the power windows and stuff come through the door via a loom or big plastic tube, do I have to unplug everything from inside the door or is there like a plug connector inside the door I can unplug?
Ken
Old Jan 30, 2010 | 10:42 PM
Aldakoopa's Avatar
Car: 1987 Trans Am
Engine: 305 4 bbl
Transmission: The kind that goes "kachunk" in 1st
Re: Had a question about door removal.
Sadly, GM doesn't put a plug in the jamb to make it easy. You have to disconnect everything from inside the door, feed it out, and reverse the process for putting the new door on.
Frozer!!!
Jan 19, 2024 04:55 PM
NiG
Sep 2, 2015 06:54 AM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
redmaroz
Aug 16, 2015 11:40 PM
