Removing windshield wiper arms
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Is there a trick to removing the wiper arms? I assumed lift up the arm and pry under it, but the arms don't lift up enough to get under them from the arm side and I can't seem to get them to pop off prying anywhere else.
Any hints?
Any hints?
Car: Used to drive a camaro
Re: Removing windshield wiper arms
There is a "latch" if you will on the side of the arm where it attaches to the wiper post. Look at it from the top and you'll see it. You can use a flat head screwdriver to pull the latch outwads, not out all the way, just enough to unlock the wiper arm from the post. Its the same approach for both sides.
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
I know exactly what you're talking about, I was wondering if that had something to do with it. Thanks!
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Transmission: Built TH350 with 3200 stall
Axle/Gears: 4th gen, 4.10
colton_carlson
Mar 8, 2019 12:21 PM
