Upgrading an 84
Old Mar 11, 2010 | 07:11 PM
badgerooster's Avatar
Upgrading an 84
I know this has probably been on here at some point but I'm tired of searching. I'm sure someone else has done it. Maybe it's against 3rd gen law or something.
I want to put ground effects on an 84 and I know it's 82-84, 85-90(I think), 91-92 as far as bumpers and ground effects. I not ecspecially picky about what years go with which. I'm looking for a certain look. I've heard there is a brace in the bumper areas that changes the fit. Could you drill out the spot welds and replace it.
Also is there a good location of pics that show the difference between years. I've gone thru quite a few pics on here and it's ends up being confusing. Some pics small, some large and so many different places. Should I just get an LMC type book or what.
I might stick with 82-84 but I haven't found any good pics yet or in the parts section.
Old Mar 13, 2010 | 11:34 AM
Re: Upgrading an 84
bump
Old Mar 13, 2010 | 01:23 PM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
Re: Upgrading an 84
I believe that on the 82-84 cars, the front and rear bumpers are different enough that in order to change to the newer style gfx, you would need to change them completely. The side gfx I believe can bolt right on. I really am not sure exactly, just basing it on what I have seen up close.
Linson
Oct 24, 2025 02:00 PM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
Zell1luk
Sep 29, 2015 10:36 AM
dbrochard
Sep 25, 2015 04:56 PM
