unibody buckleing
Old Mar 28, 2010 | 05:58 PM
86IROCZz28's Avatar
unibody buckleing
I have a 1986 IROCZ Z28. I am currently replacing the driver side floor on my IROC and when I was pulling up the carpet I noticed the transmission tunnel was buckled and the floor pan on pass side has slight tear in the metal. What is the best way to fix this? Can the car ever be straight again?
Old Mar 28, 2010 | 09:13 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: unibody buckleing
Is it possible someone hit something that found it's way across the bottom??
Old Mar 28, 2010 | 11:55 PM
86IROCZz28's Avatar
Had to also fit with the pass seat to get it out. Could explain why the windshield was cracked when I got it. Floor on pass side appears to have buckled all the way accross. It has a gap near where it attaches to the rocker. how should I fix this? It has T-tops if that makes any differnce.
Old Mar 29, 2010 | 12:13 AM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
could you post some pictures of the damage?? t-tops will make difference if the whole unibody is actually flexing
Old Mar 30, 2010 | 07:44 PM
GeeJenn91RSV8's Avatar
Car: 1991 Camaro RS
Transmission: 700 R4
Post some pics. I really want to see the damage.
Old Mar 30, 2010 | 08:46 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Some pics would tell but it doesn't sound to good. If it is buckled, whether from an accident or rust, it would need to be put on a frame straightener and that MIGHT fix it.
Old Mar 31, 2010 | 12:10 AM
86IROCZz28's Avatar
Old Mar 31, 2010 | 12:17 AM
86IROCZz28's Avatar
These are the pics of the damage that goes accross. The major buckling is in between the shifter it seems. Just double click the pics for a bigger pic.
Old Mar 31, 2010 | 12:31 AM
juanillox8's Avatar
Car: TOO MANY
weeeelll you got plenty of rust there lol. about the buckling looks like previous owner hit something and the gap is just the separation of the panels caused from the buckling. if i were you i would replace that panel as well since you are gonna replace the driver side floor panel specially with all that rust u got there.
Old Mar 31, 2010 | 12:36 AM
Gregzz4's Avatar
Car: '78 GMC Sierra Heavy 1/2
Engine: GMPP ZZ4 Q-Jet
Transmission: 700R4 Stage 2 w/Race Internals
Axle/Gears: 10 Bolt 3:42 Eaton
Am I wrong, or does it look like the Pass Side of his car was whacked?
Old Mar 31, 2010 | 12:42 AM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
hmmm wondering whats in between seats and under shifter?
anyone thinking driveshaft came apart once and smacked tunnel?
Old Mar 31, 2010 | 12:50 AM
juanillox8's Avatar
Car: TOO MANY
it can't be the driveshaft..to buckle that tunnel and separate the floor panel from the rocker panel would take aloooooot of force.
Old Mar 31, 2010 | 01:15 AM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
you ever see what a driveshaft does when they come apart at high rpm and stress?
its a violent little guy spinning between you and passenger
Old Mar 31, 2010 | 02:34 AM
Brad5117's Avatar
maybe the passenger side someone jacked it up and it slipped and separated the panels ?? that is wat happen to mine and i just beat it down where it was and then weld it back together and put some sealant on it
Old Mar 31, 2010 | 02:45 PM
Pocket's Avatar
Car: 91 Trans Am
Holes suggest driveshaft failure
Old Mar 31, 2010 | 10:44 PM
juanillox8's Avatar
Car: TOO MANY
true never thought of it like that... hey u always learned something new...
anyways back to his topic. yes it can be straight again. since u re cuttin the driverside floor to replace it. u will have access to both sides so u can work the metal with a dolly, a 2x4, and hammer n maybe a torch or a stud welder gun to shrink the metal...
BlueIroc-Z
Jun 9, 2019 03:22 AM
Veaceonee
Sep 29, 2016 08:15 PM
E Rod
Aug 28, 2015 05:17 AM
GTA-Force
Pacific Northwest Region
Aug 3, 2001 01:48 PM
