spray painting door jams? good or bad?
Old Apr 4, 2010 | 09:51 AM
kent624's Avatar
Car: 86 bird
Engine: LG4
Transmission: A4
is it a good idea to spray paint your door jams with the proper prep work? is the a rattle can worthy enough to do the task at hand? have you experienced fellows accomplished such a thing with good results?
Old Apr 4, 2010 | 10:05 AM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
Re: spray painting door jams? good or bad?
Ive spray painted an entire car and couldnt tell. The key is the prep work. Make sure you prime the door jams, wetsand the primer, then take your time spraying the jams and clear it too so it has a nice finish. If you have a mini buffer, you can even wetsand any dust or orange peel out too.
Old Apr 4, 2010 | 10:06 AM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
So you want to rattle can your jams? are you doing the body door jams, and door jams or? what color do you want your jams? are you going to have a paint supplies store fill rattle cans with your color or try finding a close color match at a local store?
Old Apr 4, 2010 | 10:09 AM
kent624's Avatar
Car: 86 bird
Engine: LG4
Transmission: A4
i want to paint both, the body and the doors themselves. and i was going to go with black or white and i was going to goto homedepot for the spraycans is there a specific brand i should use or stay away from?
Old Apr 4, 2010 | 10:15 AM
Camrs89's Avatar
Dont get the cheap paint. Ive had excellent results with duplicolor paint. Just make sure you get the correct color.
Old Apr 4, 2010 | 10:17 AM
FueledSoul's Avatar
If that's all your going to do id recommended Valspar or fleet farms brand paint. stay away from the super cheap stuff its nothing but crap
Old Apr 4, 2010 | 06:46 PM
kent624's Avatar
Car: 86 bird
Engine: LG4
Transmission: A4
ok thanks alot for the info and so you are basically saying i should get spray paint aimed for farm or heavyduty use?
Old Apr 6, 2010 | 09:04 PM
4valvemach's Avatar
Car: 04 mach1
For what you would spend in rattle can paint you could get a maaco paint job done.Do all the prep work then have them paint it for you and have a better looking car.
Old Apr 6, 2010 | 09:45 PM
FueledSoul's Avatar
His just doing the jams, rattle cans fine shouldn't take many cans at all
Old Apr 6, 2010 | 10:07 PM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
1 question. why would you paint your jams with a rattle can? to save money? it is the worst you can do to a car... if any 1 want to quotes me and say "i've done it and it looks fine" well i just have 1 thing to say. wait till you spill a harsh substance or liquid on it and you will see how good spray paint is.....
save some money and use the right stuff since you are still taking your time to do the prep work......
the only good rattle paint is the one that they actually mix on a auto painting supply store and pressurize it into a can..
Old Apr 7, 2010 | 07:27 PM
bigred75's Avatar
Car: 1992 25th anniversary RS Camaro
Engine: 305 T.B.I.
Transmission: ????
Axle/Gears: ??????
iv spray painted my whole front bumper of my car from the lights forward. i took 2 weekends sanding and another painting and wet sanding. its been on the car for well over 6 months and besides from a few scratches where i hit a curb it looks amazing. just as good as the rest of the car. If you prep it right and use spray paint that is made for metal not plastic. it will look good. iv spilled a lot of stuff on it from working on the motor and actually have even spilled paint thinner on it. i wiped it all off as quickly as possible. id say go for it man,.
Old Apr 7, 2010 | 08:20 PM
juanillox8's Avatar
Car: TOO MANY
well I Personally wouldn't rely on any paint that comes out of a rattle can to do body parts or even jams but hey maybe cuz i got the tools and the experience to use the right stuff ......
but if any of you guys did it and are happy with Your results
Old Apr 7, 2010 | 08:28 PM
FueledSoul's Avatar
spray painted all my head light buckets, rims and a ton of my parts noting wrong with spray paint the only thing to worrier about if at all is rattle can clear. . .
Old Apr 7, 2010 | 08:35 PM
Stephen's Avatar
Car: 87 GTA
Originally Posted by FueledSoul
.....rattle can clear......
You can buy rattle can clear. Saw it at the store the other day. That is all I know about it.
Old Apr 7, 2010 | 08:36 PM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
if your changing the body color of the car then door jams need painted, now taping some stuff off and using a pray paint sounds better than taking half your interior out to paint that part. and a lot of people doors drag a little so it will get scratched up so its easy to do a touch up. you dont really ever see your door jams unless your really looking at the car, from a ten foot distance youd never tell the difference if the color was pretty close. i say go for it.
Old Apr 7, 2010 | 08:42 PM
FueledSoul's Avatar
i know but i was saying it doesn't have the additives that a sealed can of clear has since the rattle can is pressurized if they left it in a rattle can the nozzle would gum/jam up....
Old Apr 7, 2010 | 08:46 PM
Ca[maro]88's Avatar
i wouldnt even clear it. your gonna paint it 64387943204340 times anyway and that clear is really crappy. depends on the brand you buy but some of them will change your color a little and it runs quicker than hell. id just paint it and leave it then when it gets messed up you aint gotta sand it down and clear and wet send and blah blah blah
Old Apr 7, 2010 | 09:18 PM
FueledSoul's Avatar
rattle can paint and clear is so easy.... why does everyone seem to have such a hard time with it? its so simple no mixing paint, reducer, hardener etc
Old Apr 7, 2010 | 10:38 PM
Ca[maro]88's Avatar
guess it was just the type i used. i always spray on cardboard or something before i spray to see what the pressure and what they spray pattern is and it came out a little yellowish. on my light blue paint it made it have a hue of green. idk. bad experience i guess. best to luck
Old Apr 7, 2010 | 10:49 PM
bigred75's Avatar
Engine: 305 T.B.I.
Transmission: ????
Axle/Gears: ??????
i just dont have money. college. sucks in the short run. epic win in the long run. lol
Old Apr 8, 2010 | 08:37 AM
Stephen's Avatar
Car: 87 GTA
Cardboard would absorb some of the paint, allowing the brown of the cardboard to tint the color your spraying on it.
Go spray white on cardboard & you'll get a "mud" color, until the first coat dries & you put more layers on.
Old Apr 8, 2010 | 09:17 AM
da.slyboy's Avatar
Car: 84 frankenstein Z28
I sprayed my door jams black and it came out looking great. Still going strong after 10 years. A good brand of spray paint is just as good as most things a professional uses. I think I only used one can to cover both jams and inner door frames.
Old Apr 8, 2010 | 09:04 PM
Ca[maro]88's Avatar
yeah i know, i sprayed it all sorts of things, just whatevers laying around really.
Old Apr 11, 2010 | 07:42 PM
kent624's Avatar
Car: 86 bird
Engine: LG4
Transmission: A4
ok great so im painting my jams and door black. the original color is white and macco and real body shops charge more than 250 for the jams alone and the just shy of a macco job
Frozer!!!
Jan 19, 2024 04:55 PM
86IROC112
Apr 9, 2016 10:20 PM
BlackTopKing
Aug 19, 2015 12:13 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
kyle5647
Aug 7, 2015 03:08 PM
