Sanding body
Car: 84 Z28 / 99 S-10 ZR2 4X4
Engine: STOCK CARB'D 305 WITH 350 HEADS
Axle/Gears: STOCK
Sanding body
I have that tape stripe on the bottom of the car. I know I can sand it off on the doors and rear panels...but what about the front plastic clip? I'm guessing if I use sandpaper Id end up scratching the plastic. So what should I do?
Car: 88Roc Flame Red Black/Gold Pkg
Re: Sanding body
Use some thinner on a rag and rub it off.
Axle/Gears: STOCK
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
Re: Sanding body
i doubt thinner alone will work but it might if the vinyl its old enough.
Car: '92 Z28 Convertible
Engine: 305ci TPI
Transmission: 700R4 shifted
Axle/Gears: 2.73 (for now)
Re: Sanding body
Agreed! Heat gun or a very good hair dryer - any remaining residue can be rubbed off with a damp cloth or goo gon then rinse...
Axle/Gears: STOCK
Re: Sanding body
Heat gun didn't work. I can't get a steady strip. It keeps breaking in pieces so I'm using a razor blade....ugh! I don't have anything else to do for the next two days so I guess I'll work on it.
Car: '88 Camaro (Gone...)
Re: Sanding body
I'd strongly urge you to try the heat gun again... It may take a while to get the strip going, but once you do you can take it off 3" at a time every few seconds.
What I did: heat the vinyl about an inch in front of the edge you are pulling up, after a few seconds the vinyl will start to "bubble" visibly. Remove the heat, and with a small thin blade screwdriver, carefully work up the back edge. (May have to do this several times to get the whole edge peeled back)
Once you have the whole edge peeled back far enough you can grab it with your finger, apply heat in the same way as above, 1" in front of where the vinyl is still attached, until it bubbles. Then you can pull it up about 3" without any effort, once it starts getting more difficult stop and apply heat again.
I'm not sure if it's breaking because it's not heated up enough, or heated up too much, or because you don't have enough of an edge pulled up before you really try to remove it... Once you get the feel for it, it's easy
Car: TOO MANY
Re: Sanding body
heat gun will not work specially if your vinyl stripe its old or faded trust me u r better off with razor blade
(its braking because its old LOOK reeeeally close and you will see small cracks on the vinyl)
Car: '87 Iroc
Engine: 350 .060 over
Axle/Gears: 3.70 9bolt
Re: Sanding body
once I didn't have a heat gun.. so i used a propane tank, the little ones from walmart meant for plumbing, and a cheap plastic edge scraper. On a white montero truck with the big decals on both doors and quarters. paint was still white afterwards.
but I am pretty good.. (don't try this unless your pretty sure of yourself)
but I am pretty good.. (don't try this unless your pretty sure of yourself) Banned
Car: 87 GTA
Re: Sanding body
I've been doing vinyl, wood & electrical signs for almost 15 years....
The eraser wheel is an absolute life saver, for not only vinyl but the adhesive residue left behind, after removing things like door body moldings, like on the C/K series trucks.
Pick one up at your local body shop supply place. This may even include Pep Boys, etc, but I've never seen one at a auto parts store, despite their body filler/pint section they do have.
Axle/Gears: STOCK
Re: Sanding body
I did the bumper and passenger side....mainly with acetone and a razor scaper. I sanded through the residue i left behind after I scraped all I could off. I used 60 grit then 320 and finally 1000.....I was amazed at myself after I finished the bumper, I primed it and it looked like a new bumper. Now I have to get those rust holes in the bottom edge of the door then I can prime the rest of the car...yay!!!!
Hotrodboba400
Dec 10, 2019 07:07 PM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
raymondandretti
Sep 5, 2015 05:02 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
