Filling in drilled holes on hatch?
Old Apr 8, 2010 | 08:01 PM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
So as you can see:
I am wondering if there is really another good way to fill them in without having to either metal patch it in or getting a new hatch. Some friends said to get a fiberglass repair kit and fill it in. Would that be an acceptable method? Or what should I do?
Old Apr 8, 2010 | 08:08 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: Filling in drilled holes on hatch?
those holes are from your aero spoiler right?
Old Apr 8, 2010 | 08:20 PM
Carlos773's Avatar
Yep was from the previous owners work and thinking having both the RS and Aero would look good together. As far as I can tell I am sure it is only supposed to have 2 holes on each side, no idea why he drilled 3. Trial and error maybe? Who knows.
But give me some ideas how to patch these up dammit!
Old Apr 8, 2010 | 08:23 PM
Engine: L31 350
yeah i remember seeing the thread where you took these off, if i knew alot about body work i would help you our carlos but sadly i cant.
Old Apr 8, 2010 | 08:25 PM
Carlos773's Avatar
Old Apr 8, 2010 | 08:27 PM
Engine: L31 350
my best guess is body filler
Old Apr 8, 2010 | 08:39 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
full take apart & weld is always best . it is often not the most practical , i'm sure you don't want to do that . a good repair can be done that will last many years with polyester resin & mat . also with a number of different body repair fillers/patch repair kits . over the years i have done all/both with good results . clean , CLEAN , CLEAN & prep of the surface/area is most important . whatever you do . good luck .
Old Apr 8, 2010 | 09:00 PM
musicfreako's Avatar
Car: 89' camaro RS TTOP
Engine: 92 5.0tpi Bosch III, headers, msd
Transmission: 700r4 built. trans go. 2,300 stall
Axle/Gears: 3:73 posi ls disc brake conversion
Are you looking to sell the aero spoiler? Is it an OE type? Thanks
Old Apr 8, 2010 | 09:53 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
I suggest going to a junk yard and getting a new rear deck. It will be easier and cheaper. It is only glued on after you remove the hatch frame.
Old Apr 8, 2010 | 10:30 PM
radical82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
Welding the holes shut is the only right way to do it. Resin and mat will work, but 'glass and metal expand and contract at different rates, the holes will show up again. A good man with a welder can weld them shut and grind the welds down and leave no trace of the holes ever being there.
Old Apr 9, 2010 | 02:10 AM
Carlos773's Avatar
Explain more! I kinda figured it might be removeable but how would someone go about this? I am guessing it will just be the bottom part of the hatch right?
Any pictures or clear details would be nice, im sure that peice alone would not cost much at local junkyards IF there is any there.
I kinda figured that would be the only good way to do it and well, I have to take it to a shop, any idea or estimate how much they would charge?
Old Apr 9, 2010 | 02:28 AM
firebird896's Avatar
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
Dude your in Chicago right? Come by my house and once I get my cheapy flux welder fixed I'll weld the patches for you, it'll take about 15 or so minutes.
Old Apr 9, 2010 | 09:18 AM
Carlos773's Avatar
I would of the car was in 1 peice and not in peices. Even more when I am thinking of rebuilding and doing the Ultimate TBI mods and maybe a gear swap soon.
I am really thinking of going the better condition rear deck and save myself the money on fixing it. It has some rust issues as well and well as you can see its in bad shape anyways. It looks like surface rust but trust me one minor poke and it will crumble.
Im a have to keep an eye on the forums or ebay to see if any pop up, last time I went to the local junkyards none had third gens.
Old Apr 9, 2010 | 03:01 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
i had the same issue, i replace my hatch completely. was going to weld but i also has minor rust around the plastic inserts so replacing was easier and cheaper, + i could do it myself. make sure to use a good sealer between the window and hatch if your replacing so you get no leaks.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
punkmaster98
Sep 30, 2015 11:01 AM
!CamaroDave
Convertibles
Sep 17, 2015 12:53 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
