Removing Door Handles
Old Apr 12, 2010 | 08:01 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
I was wondering if anyone here has any tricks of the trade as far as removing the door handles goes on a Camaro. Right now, the spring on the driver side handle is broken so it kinda flops around and the passenger side handle I broke the tab off of while replacing the lock cap and shutter so it can only be opened from the inside.
I can't angle a socket down in there and don;t have a wrench with enough reach to get to the two nuts on the back of the door handle that hold it to the door. I am hoping I don't have to remove the window.
Any pointers?
Old Apr 12, 2010 | 08:23 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: Removing Door Handles
pull the interior paneling, leave the window up get your hand up thro hole for the power window assemble (if equipped). use a 10mm wrench to get the two bolts then either a pillars or a long flat blade screw driver to pop the plastic clip. its pretty straight forward
Frozer!!!
Jan 19, 2024 04:55 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
BrianI
Aug 9, 2015 11:52 AM
3rdgenparts
Aug 8, 2015 07:09 PM
