t-tops
Old Apr 14, 2010 | 08:24 PM
supamaro383's Avatar
Car: 92 RS
Engine: 383 FIRST TPI OBDII DBW
Axle/Gears: 3.73 POSI DISK
t-tops
can anyone tell me the differance between plactic or glass t-tops. i have plactic which are crapy looking and want to put the glass t-tops but dont lacth to my 91 rs. any ideas why it wont work and what will it take for the glass t-tops to lacth to my car.
Old Apr 14, 2010 | 08:40 PM
diablood5's Avatar
Car: 1986 trans am
Engine: goodwrench 350, 4 bolt main.
Re: t-tops
i read somewhere that some t tops were factory and some they sent off.. i found this on e bay while looking for the seals for my t tops.......
NOTE:Some 82-92 Camaros and Firebirds were converted to t-top cars after they left the factory by a company called Cars and Concepts (C&C). These aftermarket t-tops are not interchangeable with the stock ones and require different weatherstripping. To determine which top style you have, remove one of the tops and measure the side the tucks into the center support section of the roof. Factory, or Fisher, tops will be 30 1/4" while the C&C tops will only be 28" long. 1A Auto does NOT stock or carry the replacement C&C weatherstripping. ......
i hope this helps
Old Apr 14, 2010 | 09:52 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: t-tops
i hope this helps
C&C T-tops should also be etched on the glass. And if the rear hatch has never been replaced there should be a C&C sticker stating when and where it was modified on the underside of the rear hatch glass near the VIN Sticker.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
meeklay812
Oct 1, 2015 03:46 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
