Replacement struts for L05 hood.
Car: 1992 Chevrolet Camaro RS
Engine: 3.1 Litre V-6
Transmission: Automatic
I have installed a factory funcional LU5 fiberglass hood (from an '82, I think) on my '92 RS and need to replace the struts. Struts made for that hood list as discontinued. Does it matter which ones I buy? They list a few choices. Thank you for any help you can give me.
Re: Replacement struts for L05 hood.
Rockauto has them. http://www.rockauto.com/catalog/raframecatalog.php If that takes you to their generic catalog page, try searching for it.
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
FYI: When the steel hood struts start to suck, they are perfect for thes SMC (fiberglass) hoods. If yours kinda suck, then just use them, or grab a set at the junk yard. Also, try NAPA if you want new ones specific for the 82-83 SMC hoods.
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Hmmmm..............The Dorman/Help and others only show one kind of hood
support.
NAPA shows 2 .......One for steel and one for fiberglass hoods:
http://www.napaonline.com/Search/Res...+50012+2012008
support.
1992 Trans Am
Aug 9, 2015 04:32 PM
