hatch troubles
Old Apr 18, 2010 | 12:12 PM
mattdirocz's Avatar
Car: 07 silverado daily/ 89 iroc/68 maro
Engine: 325ls/Carbed 350/none yet
Axle/Gears: stock
hatch troubles
Ok i never have posted for help before. Normally search for hours till i find what info i need. But here i go i bought another parts car but i cant get the hatch open and i dont have a lock in it. It was out when i bought the car i need the back plastic pieces in tack cause in need them for my car. I cant get it to open i pulled out the light in the back panel and tried pulling on the cable didnt work then tried to use a screw driver to open it thru the same hole from the light. Only problem with that is that i get the screw driver lined up with the correct hole cause on my panel the light is not in the middle of the panel. it is offset the the passgenger side. Please any help with this would great. Thanks Matt
Old Apr 18, 2010 | 12:46 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: hatch troubles
I was going to suggest removing the cargo light and trying a flat head screwdriver, but it seems you have tried that, it always works for me though. If there is no lock cylinder in the back, reach the screwdriver through that hole, and try it that way.
Old Apr 18, 2010 | 11:39 PM
mattdirocz's Avatar
Axle/Gears: stock
Re: hatch troubles
Never thought about trying it from the other side (key hole side) i just got home from work. If the flashlight has good enough batteries i will go out and try it now.
Old Apr 18, 2010 | 11:53 PM
mattdirocz's Avatar
Axle/Gears: stock
Re: hatch troubles
thanks bradley i got it simple as can be. From the outside at least, well i must have been cramped postion or lack of patience when trying from the inside. Thanks again
jrdturbo
Mar 31, 2016 02:58 PM
mrbird
Oct 20, 2015 03:43 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
formula00ra
Sep 28, 2015 11:50 AM
Lmancha96
Sep 25, 2015 08:11 PM
